Voltage light
Old Dec 10, 2013 | 06:35 PM
skillbill's Avatar
Voltage light
My 91 base 4x4 22re. When driving at normal speed my lights dim, blower motor slows voltmeter light come on the back to normal back and forth ?
Old Dec 10, 2013 | 06:58 PM
millball's Avatar
Sometimes worn slipring brushes in the alternator can cause this type of intermittant charge condition, less often, the voltage regulator might be at fault.
Also a check of battery cables and charging wire is in order.
Old Dec 10, 2013 | 11:15 PM
RAD4Runner's Avatar
See charging and Alternator system explained and test points on my sig. Use it for a simple, no-cost, quick, practical health check of your charging system, before throwing parts at the problem.
Also check condition of battery. I had leaks around my battery posts, and suspected the posts were not properly connected to cells inside, and causing erratic charging voltage. got battery replaced already. Charging system works fine now.
AkitaDog
Sep 1, 2015 08:05 AM
JHalcyonM
Aug 4, 2015 01:19 PM
msane99
Jul 17, 2015 10:13 AM
Johntom240
7
Jul 13, 2015 12:18 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
