why 91 22re pickup idle runs low after i turn lights on
The lights require voltage and the alternator probably cannot supply enough to keep up with the lights and the ignition system. At idle it's pretty normal, if the alternator can't keep up around 2-3k rpm then you have a problem.
That's normal. There's only about 3 windings in an alternator and the stator only produces so much current at a low rpm.
The only fix for it that i know of is to get a higher output alternator.
This http://i606.photobucket.com/albums/t...e/DSC02651.jpg
pic show it in the left top. That screw thats darker than the rest of the intake.
Do it while its running and it shouldn't take much. Make a mark on the housing so you know where you started and only go a half turn or so then you'll hear it idle up or down. Then try the lights. Since you don't have a tech it has to be by sound. Optimally on my 4x4 5 speed its like 750 rpms. But ive run it at 1100 when 4 wheeling because the which needsmore amps.
