89 22re Delayed engine turn over need help please!
Hey I've got an 89 22re x-cab 4x4 with 159k. The issue I'm having is that about 80% of the time I go to start it, I have to hold the key in the crank position for quite awhile (sometimes more than 30 seconds). Never the less, it still starts up eventually. The other 20% of the time it starts normally. It doesn't have anything to due with temperature or sitting around. It can sit overnight and start just fine or I can turn it off for ten minutes after an hour of driving and it will give me trouble. No other mechanical issues I have found. Everything else is perfect.
Any ideas?
Thanks for the help!
Any ideas?
I would say either the starter or the relay, theres a few threads on troubleshooting both, sounds like a weak contact point somewhere in the system and its taking a bit longer for the connection to be complete. Rad4Runner has a great write up on the starting system
