Need help w/ dashboard airbag cover removal
Old Apr 29, 2013 | 10:46 AM
TidalVA's Avatar
I have done some searching but cannot find the answer. Is it possible to remove the dashboard airbag cover in a 3rd Gen 4Runner in order to swap with a new, clean cover without damaging or tampering with the actual airbag? If so does anyone have instruction? I would like to find a clean cover from a junkyard or elsewhere and swap it out with the damaged cover on my dash. I am hoping it can be achieved without total dash and airbag removal. Thank you.
Old May 1, 2013 | 03:39 AM
TidalVA's Avatar
Anyone?
Old May 1, 2013 | 06:05 AM
brianh699's Avatar
It's sold as a single unit, there's probably a way to remove it but maybe not that pad splits in the middle when the airbag deploys
Old May 5, 2013 | 06:30 PM
aowRS's Avatar
I've wanted to know the same for at least 10 years - after a some lumber I had in the truck made a small cut in the cover.
Andreas
Old May 5, 2013 | 06:48 PM
pattycakes77's Avatar
I know I've had the bottom portion loose but couldn't figure out how to get the top released without breaking so I quit before causing some wallet damage $$. Seemed like it just had a couple more tabs and it would come off separately from the dash and air bag but I can't say for sure.
Old May 5, 2013 | 08:15 PM
crazypaint's Avatar
That whole pad comes off they are sometimes a pia. Should be a few screws around and then it's just clips under the pads. Easiest way to see is to find a pad that's already taken out
Old May 12, 2013 | 08:58 AM
TidalVA's Avatar
Thanks for feedback so far. As soon is I find a junkyard 3rd gen, I'll see first hand. Hope it can be done.
Old May 12, 2013 | 07:50 PM
KZN185W's Avatar
you'll need to access the clips/tabs from behind to remove the cover.
Old May 12, 2013 | 09:35 PM
TidalVA's Avatar
Thus, only getting behind by removing the dash entirely?
Old May 13, 2013 | 07:29 AM
KZN185W's Avatar
as a minimum you'll need to remove the upper cover of the glovebox compartment. the upper cover is held by a few screws.
<img id="ums_img_tooltip" class="UMSRatingIcon">
Sep 4, 2015 09:27 AM
TJWilly
Jul 31, 2015 02:05 PM
PopsDad1
Jul 30, 2015 02:21 PM
irritech
Jul 27, 2015 05:15 PM
icentropy
Jul 9, 2015 02:12 PM
