Timing job. How to, parts, and tools needed.
Ok so my 5vz 3.4 is soon gonna get her timing and water pump replaced and I'm looking for so tips tricks and parts and tools list before I dig off into the project
Buy this http://www.ebay.com/itm/Toyota-TIMING-BELT-WATER-PUMP-KIT-Genuine-OEM-Parts-4-Runner-Truck-3-4L-V6-/180729034728?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AToyota%7CModel%3A4Runner&vxp=mtr&hash=item2a144a37e8 or this http://www.ebay.com/itm/Toyota-3-4L-V6-Complete-Timing-Belt-Water-Pump-Kit-/190521450224?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AToyota&vxp=mtr&hash=item2c5bf69ef0 and a crank bolt from your local Toyata dealer (it's listed as non-reusable per the FSM) and you'll have all the parts for the job.
I use this for a crank holding tool as it alaso works well for the cams.
Keys to a good 2x4 build:
1. Leave lots of wood PAST the hole;
2. Do NOT put the bolts on the centerline; put them on the diagonal.
If you do not follow these two rules, you WILL split the 2x4.
I was a carpenter summers in college. This thing took less than twenty minutes to build. No plans, no measuring.
1. Put socket on board, draw a circle around it.
2. Drill out circle.
3. put drill bits in pulley holes and and socket on crank bolt.
4. Fit hole in board over socket and hold against bits. Bash board with BFH.
5. Drill 3/8" holes at dimples and put 3/8" bolts in holes. Done.
DacodaYota
Sep 2, 2015 02:13 PM
bigblue82
10
Jul 6, 2015 08:27 AM
