What Large Sockets For Toyota Work?
Old Feb 21, 2013 | 06:19 PM
wrenchtech's Avatar
I stumbled on a good deal on 3/4" drive breaker bar today. Now I want to know what size sockets I should look for. On the small end I see that I cold find a 19mm. Maybe I'll try to go as low as 17mm. What other sizes would be useful? I know 3/4" drive sounds like overkill, but when you live in the rust belt it comes in handy.
Old Feb 21, 2013 | 06:44 PM
Co_94_PU's Avatar
I must be somewhere near the rust belt I though 1/2" or bigger was standard kit. The lug wrench I use for torsion bars is 11/16th IIRC so yes to a 17mm.
Hub nuts(2wd&4wd differ?), diff drain plugs, strut bars, cab and bed mounts, frame cross brace, rear engine/tranny mount, spring mounts, diff u-bolts.
Those are all the ones that come to mind off hand but I don't have the sizes handy. Please if someone could fill them do. Thank you
Old Feb 21, 2013 | 06:48 PM
Roark's Avatar
I know 17 is used on the transmission, and I think either 19 or 21 is used on the crossmember bolts. And then a 21 or so on crankshaft bolt. You know, I'd just invest in a high quality set of 16 or 17+.. It's always useful to have that bolt when you need it
Old Feb 21, 2013 | 06:49 PM
snobdds's Avatar
19 -24mm, 30mm. That will cover lug nuts, shock nuts, Front/Rear Diffs, TC, tranny, Pinion nut, suspension castle nuts, etc.
Or...
Just get 1 3/4 to 1/2 adapter and use your old socket set.
DeathCougar's Avatar
17mm, 19mm, 21mm (Lugnuts), 22mm, 24mm, some 27mm and 30mm stuff. 54mm socket for front spindle nuts.
Fwiw, the ONLY thing on a Toyota that is 21mm is the LugNuts
Old Feb 21, 2013 | 06:53 PM
Roark's Avatar
Or...
I've broken a few craftsman adapters on bigger torqued bolts..just a warning, I suppose.
Old Feb 21, 2013 | 09:22 PM
wrenchtech's Avatar
Well good! 17 and 19 are on the way, and I've already got one of those 54mm stamped metal spindle nut sockets.
gillesdetrail
Nov 19, 2019 12:56 PM
voiddweller
19
May 2, 2016 09:10 PM
gog1968
Jun 22, 2015 05:55 AM
AustinTaco
Jun 21, 2015 09:54 AM
