Need some extended shock advice for 4" rear lift
Hey guys, sorry if I sound like a total newb; I'm kinda new to the whole 4x4 thing. I did some searching but couldn't really find a good answer.
Anyway, I just bought this truck about a month ago with what looks to be a 4" lift in the rear(I measured the rear blocks to be about 4" tall) and cranked torsion bars in the front. The truck has some aftermarket shocks(not sure what kind, all I know is they're blue) but I don't think they're extended length.
I had a chance today to try some flexing and I'm pretty disappointed, especially since I have both sway bars removed. I have a feeling the previous owner just put on some factory replacement shocks that aren't extended length which I think is the reason for my poor flex.
Here's some pics so you can get an idea what I'm talking about. I apologize for my ugly truck, she's been through hell!
So those of you that have a 4" block lift in the rear, what shocks are you guys running?
Thanks!
All help is greatly appreciated!
Alec
Thanks!
Alec
It looks like those shocks stock length if not shorter.
You can search to web to find the size of the shocks meant for 4" lift kit.
Take those dimensions/numbers to any local parts store, they should be able to cross reference the size and get you some decently priced extended shocks.
If not, then you can always order some new shocks designed for your lift i.e. skyjacker, superlift, etc ($$$).
$23.79 each http://www.rockauto.com/catalog/catalog.php
If you go to some of these shock mfg's websites, they have charts which show bushing size, extended and compressed lengths, etc. Also they will tell you which of their shocks are suited for a particular lift. Rancho has the chart I'm describing. Do a little bit o' reasearch...
Best way is to check your compression and extension length of your shock axle mount to your shock frame mount. Remove your shocks and cycle your axle. This will get you some idea of the numbers you should be looking for.
Now my question is, can shocks with more travel be ran? Based on that chart, it seems like the Monroe PN# 34964 would definitely work, but I also see the PN# 34687 has almost 3" more travel. Would those work with my 4" lift or is it too large of a shock? If not, could I maybe use the PN# 34685? I want to get as much flex as I possibly can.
Thanks!
Any help would be greatly appreciated!
I have an 85, and I think off the chart I am going to go with the 34930's with about a 4" lift for the rear. can anyone confirm the bushings are right on this shock?
also about the front, does anyone have any idea where I can find that chart like for the kind that have the loop on the bottom and the stem on the top?
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
FS[NorAtl]: 05+ tacoma leveling lift front MA
akaphilly
Jul 9, 2015 02:18 PM
Vargntucson
Jul 4, 2015 12:15 PM
