3vze FPR
3vze FPR
I have a 92 3vze that is missing, bucking, and some almost dies I can try and rev it up a few times and sometimes it will go. I pulled the vaccuam lines off the fuel pressure regulator and the big line has gas in it I was trying to find out if it is bad and could this be causing my problems
Sure is a strong possibility. if there's gas in the vacuum line than the internal diaphragm is busted and fuel is being sucked into your intake. Not to mention that the FPR isn't doing its job properly.
http://personal.utulsa.edu/~nathan-b...89fuelpres.pdf
http://personal.utulsa.edu/~nathan-b...ne/99fuelp.pdf
