i killed the truck
i killed the truck
My girl drove the truck home and it was empty. I put 5 gallons of gas that had been in my garage (w/stabil added) for a couple of months in my girl's 4runner. It wouldn't start. I added another 5 gallons of fresh gas and some B-12 fuel treatment. Still won't start. I feel like an idiot. Before I go and drain the tank and fill it up again in hopes of a miracle I was hopping for some advice or direction to guide me.
When you say it was empty, like almost dry? When older tanks are run that low, lots of time they suck sediment into the fuel lines or pump.
Do you have gas at the motor? If not, is the pump running, and when was the last time the filter was changed.
Just some things to look at. If it hasn't ran with the bad gas in it, it's unlikley you caused any serious damage.
Try the fuel filter.
i have had very bad luck with the gas stabilizer it was the only vehicle I put it in .
That I ended up pulling the pump and filter
All the others I never used it no real problems getting running after a few months or years.
find the schrader valve on the fuel rail and see if it squirts gas. hit the key and listen for the sound of the fuel pump. Check for clicking fuel pump relay. Then take off the air intake and squirt some carb clean in the t body and see if it fires. Then get a test light to see if your gettin power to the pump.
With the key to "ON" the fuel pump should NOT be running. With the key to "START" the fuel pump will run, but I sure can't hear it over the sound of the starter.
I've never seen (or heard of) a Toyota truck with a Schrader valve on the fuel rail. Of course, I haven't seen every truck, so Dave may know something I don't.
Your right it not really a schrader valve but its kind of like one where you hook up a pressure guage. If you press on the little needle gas will squirt out if theres pressure.
My post was general field diagnosis and should have been more toyota realted.
On Toyota trucks, the Circuit Opening Relay (COR) turns the fuel pump OFF as soon as the engine stops sucking air through the VAF. If you get in an accident that breaks a fuel line, you don't want the pump running!
The COR will run the pump with the key in the START position, then the VAF signal takes over.
There is a check valve in the pump to hold pressure in the fuel rail with the pump off. If my truck sits for a week or so, that pressure will drop far enough that I have to crank it for a second or two to re-pressurize the rail. (There's no air in that line, so it isn't a matter of "priming" the line.)
I don't know anything about GM vehicles since the days of mechanical pumps, but I suppose that it's possible that some will run the pump (just for a few seconds) with the key to "ON" to re-pressurize the fuel rail. So you might be able hit the key and listen for the pump, but I don't know.
General field diagnosis is good, but telling somebody to "listen for the pump" when the pump is SUPPOSED to not be running may not be helpful.
