header wrap for 22re intake tube
Has any body ever tried wrapping the stock plastic air intake tube with header wrap to block out the hot engine air, so you could keep the already cold air from the stock box cold before it reaches the engine, any insight is good
I'm pretty new to Toyotas but I've seen (I think it was on 4crawlers) a battery/air box swap that eliminates that long plastic tube running over the radiator. Which would also solve any radiator/air tube heat soak issues.... Good luck!
thanks guys, it was just a random thought i had the other day and was just curious, and thank you ugly4runner i have seen those as well but didnt wanna have to go through all that lol
Cold air will increase the power output. Hot air helps fuel econ'. A shorter intake tube helps with throttle response.
The computer if it was engineered correctly should be taking into account the heat soak in the tube. Never bothered to look to see if anyone has quantified/measured this tep difference. Jam another sensor into a sacreficial intake tube near the throttlebody, take a reading with stock and shielded intake tubes.
