Piston rings/ valves
Old Feb 9, 2013 | 12:48 PM
HIGH_MTN's Avatar
3.0
My runner was running rough, came time for smog, did a tune up. I failed with high HC, got home did a comp test n cylinder 5 is dead...40psi put some oil in came up to 60psi...ask around and looked on here. It points to piston rings but some local mechanics says it can also b the valves..
just want to noe wat everyone else thinks...
By the way I passed smog since it was HC (too much unburnt fuel) I figured ill unplug the #5 cylinder injector plug n try it...wat a miracle it passed..
Old Feb 9, 2013 | 06:10 PM
Co_94_PU's Avatar
Pull the intake exhaust and valve cover, add pressure and decide where it's leaking more. Valve seats, or rings. You can probably get by with leaving the manifolds connected and just checking around the seals.
You got a 50% increase by adding oil so you know the rings aren't holding, safe bet is to just rebuild.
Old Feb 10, 2013 | 05:06 PM
HIGH_MTN's Avatar
[QUOTE=Co_94_PU;52039705]Pull the intake exhaust and valve cover, add pressure and decide where it's leaking more. Valve seats, or rings. You can probably get by with leaving the manifolds connected and just checking around the seals
You got a 50% increase by adding oil so you know the rings aren't holding, safe bet is to just rebuild.[/QUOT
Ok thanks
4.34runner88
Feb 7, 2016 02:24 AM
_Nicco_
Sep 21, 2015 03:06 PM
LotOMiles
Sep 14, 2015 11:45 PM
old87yota
Sep 9, 2015 12:39 PM
idadan208
Sep 7, 2015 09:06 AM
