2000 Air Mix Control and Servomotor
So i have been getting lukewarm heat for some time (months). And in the summer, the A/C was becoming increasingly warm. Just seemed lukewarm was the only setting. So I pulled the Servomotor after seeing that it doesn't move when I change the temp control from cold to hot and back. I was able to move the air mix control "arms" and have good hot air blowing. They are stiff, however, which may have led to the servomotor failing.
What should I lube those arms with (thinking white lithium) and how can I test the servomotor before I replace it?
Lubricate the cable
I wanted to start giving back. I have been having this problem and I read a lot and followed directions - I took the servo apart and spun the arm so that the plastic gear wheel had fresh teeth.
But.. I wondered what made those teeth strip in the first place? So i tried manually moving the control to switch from hot to cool air and it was tight! So I unhooked both ends of the cable and I lubricated it using a lubricant for plastic - and put everything back together. Good so far!
I would lubricate the system to make sure that servo doesn't have to do too much work.
Good luck.
Good luck.
FS[PacNorWest]: Parting 2000 4Runner Limited 4WD Marysville, WA
DeathCougar
Apr 1, 2018 11:29 PM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
Sep 9, 2015 06:24 AM
sojourner567
Jul 16, 2015 08:52 PM
