universal synthetic transmission fluid. Any Good?
Got a price to do a transmission fluid change and the shop uses a synthetic that they swear by. It has a long list of fluids that it can replace including all of the dexrons 1-6. Just wondering if its any good or if I should stick to the dexron 2 or 3. not sure if I can post this link but its made by service pro and is a full synthetic. Thanks Jesse http://www.service-pro.com/documents...VehicleATF.pdf
x2, you're good to go.
Interestingly enough, I found another universal ATF/PSF like that one recently. While searching for the ever elusive Toyota PSF Type EH(P/N 008886-01). Which I eventually found(proving it really does exist). But that's not exactly relevant...at the moment. However, the quote I've taken from this TDS is...
Divinol ATF-C Premium VI
Manufacturer performance
Recommended as servo oil for following cars:
Characteristics
Application
Divinol ATF-C Premium VI is suitable as transmission oil in automatic transmissions of cars, trucks, busses and
special vehicles. Also possible for hydrodynamic converters, hydraulics and servo-steerings in accordance to
manufacturers` specifications.
Technical Data Sheet
Product description
Divinol ATF-C Premium VI is a clear colored power transmission oil for automatic transmissions and offers following
characteristics:
characteristics:
• Superior oxidation stability
• Very good anti wear characteristics
• Premium cold flow properties
• Broadly temperature range deployment
• Not aggressive to any sort of seal
• Very good shear stability
• Suitable for prolonged oil drain intervals
• Universal deployable ATF
Specification
GM Dexron VI; GM Dexron III G/H; GM Dexron II D; GM Dexron TASA; Ford Mercon V; JASO 1 A
Allison C4 / TES 295; BMW 7045E / 8072B / LA2634 / LT 71141 / P/N 83220142516; Chrysler ATF; Honda ATFZ1;
Hyundai SP-II / III / SPH IV* /NWS 9638*; JWS (Aisin Warner) 3309 / 3324*; KIA SP II / III; MAN 339 V2/Z2
sowie 339 F; Mazda ATF M III/V; MB Freigabe 236.1 /236.2 /236.3 / 236.5 / 236.6 /236.7 / 236.9 / 236.10 /236.11;
Mitsubishi Diamond SP II/III/IV/ATF-J2; Nissan Matic D/J/K/S; Nissan 402; Subaru ATF / ATF HP; Saab 93 165 147;
Suzuki 3317; Toyota T III/IV/WS; Volvo 97340 / 97341; VW G 052 162 / G 052 990 / G 055 005 / G 055 025 / G 055
162 / G 060 162; ZF 03D,04D,05L,09, 11B,14A,14B,16L, 17C
Tests for Voith H 55.6336 approval done until 2012.
* Suitable after OEM car warranty
Acura P/N 08206-9002 A; Chrysler MS-1872, MS-5931, P/N 04883077, MS-9602, ATF+4; Ford M2C 195-A; GM
P/N 89021184, GM 9985010; P/N 1052884; GM 9985835; P/N12345866; Honda P/N 08206-9002 A; Hyundai PSF-
3; Kia PSF-3; Mercedes-Benz 236.3, P/N 000 989 88 03; Mitsubishi PS Fluid, Diamond SP III; Nissan PSF-II;
Saab P/N (45) 30 09 800; Subaru P/N K 0209 A 0080; Toyota PSF Type EH, P/N 008886-01
Characteristics
Density/15°C / DIN 51 757: 848 kg/m³
Colour / DIN ISO 2049: Clear
Flash point (Cleveland) / DIN ISO 2592: 208 °C
Pour point / DIN ISO 3016: <-35°C
Viscosity/100°C / DIN 51 562: 7.5 mm²/s
Viscosity/40°C / DIN 51 562: 36.7 mm²/s
Viscosity index / DIN ISO 2909: 181
Application
The 4runner transmission holds a lot of ATF and a full synthetic changeover will be expensive.
I've got 331,000 miles on regular over the counter ATF and she's still going strong.
Don't waste the money............just my opinion.
That's kind of a relative statement, don't you think? A lot compared to what?
A340E:
Dry fill 7.2 liters (7.6 US qts, 6.3 Imp.qts)
Drain and refill 1.6 liters (1.7 US qts, 1.4 Imp.qts)
A340F:
Dry fill 10.2 liters (10.8 US qts, 9.0 Imp.qts)
Drain and refill 2.0 liters (2.1 US qts, 1.8 Imp.qts)
ATF D-II or DEXRON® III (DEXRON® II)
http://ncttora.com/fsm/1996/SIL/tech...pp/at/lubr.pdf
I agree. Considering that full synthetic ATF is generally almost 2 to 3 times the price of good ol' DEXRON III(or equivalent). ~$3.50/quart vs. ~$6-$10/quart. And if you're talking between 8 and 11 quarts to dry fill a tranny(or more to flush it), it adds up...QUICK!
If I was rich, I'd use synthetic. But since I ain't, I just make sure that any automatic transmission I own gets flushed + a new filter + refilled with the cheap stuff every 30k miles. Which is usually more than adequate preventative maintenance wise.
A340E:
A340F:
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
