New member. Any one do a CB Coax Install through roofrack?
Hi.
New member. Looking to get rid of magnetic antenna and install firestik antenna to new safari rack i am getting. I was thinking of trying to run coax thru rooftop under the factory track at top cap point on driver side(there is small hole underneath). Then down inside along driver side seat belt panel to floor. Has any one done this or any other good options for wiring?
Thanks RJ
98 4RNR SR5 4WD
Here are some pics of Rig. How do you get larger pictures to post and not just thumbnails?????
New member. Looking to get rid of magnetic antenna and install firestik antenna to new safari rack i am getting. I was thinking of trying to run coax thru rooftop under the factory track at top cap point on driver side(there is small hole underneath). Then down inside along driver side seat belt panel to floor. Has any one done this or any other good options for wiring?Thanks RJ
98 4RNR SR5 4WD
punks_is_4x4
Aug 21, 2015 01:35 PM
Esibnitsud
Jul 30, 2015 08:19 PM
Athansinis
Jul 27, 2015 08:38 AM
