PDA
View Full Version : 03+ 4Runner/GX470, & 05+ Tacomas
Pages : 1 2 3 [4] 5 6 7 8 9
  1. Weird Shimmy when I start to go or corner.
  2. 03 and up 4 runner question.
  3. Will a 05+ Tacoma TRD Skid Plate Fit?
  4. Rear wheel bearing replacement
  5. Toyota Recalls Some 2010 Tacoma Trucks
  6. 4th Gen + Pole = Crunch
  7. 2005 4 runner passenger window replacement
  8. Which wheel is 'A' wheel 03 4runner.
  9. 2004 4Runner 4WD won't engage
  10. 08 TACO double cab - need pics
  11. Volant Air Intake fits 2008 4.7L 4Runner
  12. Increasing height of 4th gen
  13. Looking for new car, Any Problems with 03+ 4runners
  14. 2005+ Tacoma Bed Rack Options
  15. N-Fab Tacoma Light Bar T054LB
  16. What it takes to Convert a Prerunner 4.0 Ext cab TRD to a 4 wheel drive.
  17. 07 Tacoma Prerunner exhaust question
  18. 2007 4Runner V6 PCV location
  19. 07 4runner shaking
  20. 4runner grille help
  21. trd exhaust
  22. 2007 Tacoma 4.0L - Flowmaster Original 40?
  23. Wiper Blades Not Returning To Start Position
  24. lockers and lift?
  25. 2007 toyota trd sport bearing
  26. 04 V8 4runner cold start knock
  27. Baja Mule Roof Rack
  28. Washer Pump
  29. 2006 4runner: 4wd won't engage
  30. Toyota Floormat Recall Information
  31. 03-05 4Runners - Need/Want a light bar?
  32. change 2004 4 runner dash lights
  33. HID Install Issue - Please Help!!
  34. 09 access cab 2.7l/ 5speed/ 4x4 clutch issue
  35. Will 275/65/20 on 20x9.0 rub?
  36. Help can't turn key off and get key out of ignition!
  37. 2wd 4Runner in Snowy Mountains
  38. Fan rubbing on radiator shroud?
  39. 03 4runner sr5 w/ strange windshield issue
  40. Will stock 16" 2001 Sequoia wheels fit a 2007 4R?
  41. 2004 4Runner V8 TRD Exhaust Questions
  42. 2005-2010 tacoma pace edwards toneau cover
  43. 2003 highlander, interference engine or not?
  44. Rear end diff housing and axle totaled
  45. Gearing
  46. Shock Suggestions
  47. 2005 Highlander 4WD strut/shock question
  48. FZJ80 wheels into 05+ taco
  49. new taco
  50. serpentine belt change
  51. First offroad for this 05
  52. From Show & Tell to No & Tell
  53. New 2010 Tacoma
  54. New Pro-Comp wheels
  55. Model specific 4WD questions
  56. 2009 Tacoma, Transmission Going Out at 12,xxx miles???
  57. Anyone Notice this w/ ATRAC?
  58. '04 4Runner Tire Noise?, but really bearings?
  59. 2005 4Runner Sunroof Stuck Open
  60. Sunroof Seal replacement
  61. Exterior Lighting
  62. Hood Sccop
  63. 2003 4runner Sport Transmission whining?
  64. '05 Tacoma V6 4x4 MPG?
  65. console light?
  66. Cold air from heater at idle
  67. Lift my 4Runner
  68. Shimmy with tire rotation.
  69. Roof Rack Question
  70. Codes for 2006 4Runner....
  71. New Runner! But need a part :(
  72. New here and new mods I performed ...
  73. Fuel Door Replacement
  74. backoff xp
  75. 97 4-runner engine swap
  76. Master power window switch question
  77. 2004 4Runner 4wd front rotors replacement
  78. rear end help
  79. Key FOB stopped working
  80. Help with reargate mod
  81. Doug Thorley Header Update
  82. hello everyone!
  83. 07 yota low lock ??????
  84. 4runner front wheel bearing replacement
  85. 03 Limited 4x4 with the v8 and it is loaded
  86. 4runner Y pipes
  87. Interior door panel damage beyond repair
  88. 2004 Toyota 4runner actuator
  89. new to 4th gen
  90. NEED HELP New 09 4Rnr Not Enough Headroom
  91. New to 4th Gens (Stock Pics)
  92. 03 V6 4Runner: Broken gear selector question
  93. Can't remove front axle
  94. VSC TRAC lights on, no codes come up
  95. Sourcing and installing drive axle
  96. 4th gen manual transmission
  97. Ticking noise from v8 engine?
  98. What tires should I get?
  99. just bought a 4th gen
  100. 04 runner front end swap
  101. FJ front coils on 4th Gen
  102. 08 4Runner Downshifting Issue
  103. Resurfacing Rotors
  104. Doug Thorley Questions and Answers
  105. led knight rider light
  106. 03 4Runner Transmision Fluid Change?
  107. Doug Thorley Header Update 07/16/09
  108. My 4Runner Jack isn't tall enough
  109. v6 or v8???
  110. Clanking, sheetmetal banging sound
  111. tacoma bed side
  112. Doug Thorley Header Update as of 07-08-09
  113. Rattle from Underneath
  114. 06 4runner v8 4.7 tranny question
  115. Recirculated air button "auto on" issue
  116. TRD Shock install on 09' Taco!
  117. 07 Taco front mud flap sheared off...
  118. Tacoma Front Clip on a 4Runner
  119. Doug Thorley Header Update for the 4Runner 4.7 V8
  120. 05 + UCA/CO Install pics.
  121. compression issue
  122. Tacoma Getting Beat On at Katemcy Rocks
  123. lighting or replacing instrument cluster on 2003 sr5 4runner?
  124. Feeler: Demello Bolt-on Sliders for 4th Gen 4Runners?
  125. Just bought an 07 Taco Double Cab SR5...
  126. 4runner year question?
  127. 4th gen rear spoiler?
  128. Headers for 2004 4Runner
  129. Looking for a truck
  130. Passenger side mirror
  131. transmission question help!
  132. Help!! 04 4Runnwe Oil temp light on and the truck back up in D
  133. 2004 4Runner Spark Plugs
  134. Differential bolt torque specs
  135. Inner CV boot failure
  136. air intake question
  137. Coil-Rite Airbags installed.
  138. what to look for
  139. best oil for v6 03' runner??
  140. 04 4runner, 06 taco lift kit?
  141. Made the swap 4Runner to Tacoma
  142. Front end floor jack lifting point
  143. What is done in a 60,000K Service
  144. Differential drop
  145. Another Coolant Flush Post
  146. Took up Running
  147. Bad Odor when Accelerating
  148. Thinking of painting the fender flares on my Tacoma
  149. Delay in acceleration in my 04?
  150. Total Chaos Lower Link Skid
  151. Climate Control Dash Light Replacement
  152. Surface rust on an 07 Tacoma?
  153. Check out the lift
  154. New 4th gen Runner owner, headunit questions
  155. 4th Gen 4runner...TRD Exhaust or go back to stock??
  156. Made offer on 07 TRD Tacoma.....
  157. Excess carbon out of tailpipe
  158. Add TRD to Tacoma
  159. I am back...no biggie but i missed ya all
  160. How much to repair? Need your opinions
  161. 03+ 4Runner tire sizes
  162. Diagnosing - Master Brake Cylinder
  163. Diagnosing - Master Brake Cylinder
  164. 4runner brake upgrade? - similar to tacoma/tundra swap
  165. 2005 2TR-FE Four Cylinder Excessive Carbon Buildup
  166. Normal Oil Pressure?
  167. Bilsteins shocks and coil question 4runner
  168. Bilstein 5100 all around or OME kit?
  169. Foul smell out my AC 2003 4Runner
  170. Looking for good new shocks cheap/ want durability
  171. Loud window "pop" when rolling down drivers window on 2006 4Runner
  172. Does the 2004 4runner come without xreas?
  173. 04 4runner struts and shocks both front and rear
  174. Looking for a totaled 03 4runner with a clean title
  175. CV inner clips - where to buy
  176. Intermittent Airbag light - No code at the dealer
  177. Help Deciding on Diff Ugrade....
  178. noise in reverse
  179. adding onto previous vsc trac light thread with blinking tire/exclamation point lght
  180. 04 vsc trac light with tire press light
  181. tire pressure monitoring system
  182. '03 dual HVAC: a/c light flashes
  183. New Cat-Back
  184. 09 Tacoma Insight Needed
  185. Introducing myself with pictures - Questions on Exhaust / Supercharging
  186. 2005 v8 4runner air ride malfunction
  187. X-Reas life span
  188. 2x4 to 4x4
  189. How "transferrable" are tacoma warranties?
  190. Cargo mats
  191. Alarm Mod?
  192. HELP with suspension
  193. 5-Speed Auto Tranney swapping a 4-speed...Doable???!
  194. Factory Alarm Problems
  195. '05 Taco Lug Nuts
  196. trd tube steps
  197. my new old '03
  198. Anybody know? What years of 4Runners have rear Elock with Disc brake?
  199. New 4th Gen Advice
  200. lowering 09 tacoma 2wd??
  201. fitting 15" wheels on 06 taco??
  202. 03 X-REAS Bouncing after replacement
  203. NO REVERSE...on my Auto Trasmission Toyota
  204. TOYTECLIFT rear coil better than OME ???
  205. Squeak...Squeak...Squeak Coming from wheels
  206. Can You lift a 4th Gen 4Runner With The Rear Air Suspension?
  207. Rim question
  208. '09 Taillights and Headlights
  209. Fabtech 6" FJ lift on 03 4Runner???????
  210. New-to-me runner; mod ?'s
  211. '05+ Tacoma TSB's
  212. 4th gen vs 5th gen
  213. 2005 taco Help.
  214. 05 4Runner TRD Sport
  215. Repair/Replace door section under window????
  216. front passenger brake caliper
  217. New lift has arrived but need some help
  218. Hardwiring GPS (Garmin 265WT)
  219. Holes to drill for ARB bumper
  220. 05 r4unner vibration after hitting hard bump
  221. Limited Brake Caliper Wheel Conflict
  222. 04 4Runner parts swappin ??W/SE
  223. Low Beam Headlight Problem / DRL?
  224. 05 SR5 dash lights??
  225. 03 4runner ltd 4WD wont disengage
  226. 05 Key fob
  227. 04 4R hub nut torque
  228. 2-Jaw Puller Tool for Spindle?
  229. VSC Trac VSC Off lights on all the time HELP!!
  230. Optimal jack/stands for suspension work
  231. Blacked Out Emblems, Tinted Tails, & LED strips Installed!
  232. moderate lift and or bigger tires 03 v8 4runner sport 2wd
  233. Daystar 1" Budget Boost - Actually 1.75" Installed
  234. Tacoma x-runner
  235. Cargo system/spare tire carrier in trunk (4Runner)
  236. Spare tire carrier
  237. 22" Rockstars, Nitto TG's, Cornfed 2/1 are ON! (Many PICS!)
  238. leaking on driver side floor HELP
  239. $%@# bulb out!
  240. 05 tacoma bench seat repair
  241. Comfort: Tacoma Crew Cab vs 4-Runner
  242. heater blower problem
  243. lift kit/tires
  244. purchasing 4runner
  245. S/C 2.7 2009 Taco?
  246. '05 Tacoma Frame Failures
  247. Picture of xreas?
  248. Interior Lighting Converted to LED (Many PICS)
  249. 04 V8 vs. 05 V8
  250. Wheel berings on 03 4Runner
