best ball joint for 2nd gen 4runner
Old 04-23-2019, 02:23 PM
Guillaume Thewood's Avatar
Looking for the best (grease able) ball joint money can buy(lower & upper). Testimonies ! not personal preference plz. ive seen a few one where you cant pump grease once they are install since you cant reach the zerk fitting, so yeah definitely not putting that on my truck if they cant even engineer that, im very doubtful they can design a ball joint XD
thx guys !
Old 04-23-2019, 08:19 PM
Andy A's Avatar
My vote goes to Toyota/OEM. My originals lasted for 240,000 miles so when it came time to replace went with Toyota/OEM.
Old 04-23-2019, 10:47 PM
ev13wt's Avatar
OEM no doubt. JUst looking at the machined surface where aftermarket is simply painted and left that way
I have had about 6 aftermarket ones in there, they all fking fail / suck / get play. Even had one with a nylon lock nut. Scary stuff.
If you find a good alternative, let us know!
RAD4Runner (04-27-2019)
Old 04-24-2019, 01:15 PM
keycw's Avatar
your going to be hard pressed to find anyone on this site that tells you anything other than OEM for the best parts for your truck.. that being said last time I checked you could get 555 balljoints from rockauto branded under beck/arnley for about 25 bucks a piece... although 555 is not factually a Toyota genuine part, most people will agree that's is the next best thing.
millball (04-24-2019)
Old 04-24-2019, 08:13 PM
Co_94_PU's Avatar
From what I recall off hand you can get this "555" casting mark from a cloned part, manufactured in who knows where...
If you want a decent warranty buy from your local dealer and hope they give a crap..
Worth noting that if you have any non-standard geometry (lift!) It's not thier fault when (if?) it fails..
I don't know what is in my RET, I carry a spare set of cheep ones from Rock auto and the tools to change them if the need arises..
Actually it has a plethora of tools, parts, and plugs. As long as it's not one of the aluminum rims or a cam I am hopefully covered.
Old 04-25-2019, 03:31 AM
arlindsay1992's Avatar
OEM only. They lasted this long. It should be a no-brainer. All the other brands develop play super fast with or without a lift. Some have really bad seals that tear and let all the grease go everywhere and water/grit in. The absolute worst ones I've seen are Moog. This is somewhat surprising because they are a brand with a supposedly good reputation, but they are truly the worst ones.
Old 04-25-2019, 06:25 AM
snippits's Avatar
I have a two wheel drive with 555 Made in Japan upper ball joints that I installed a little bit over two years ago. Still working good. Have a grease fitting, and a nipple to expel the old grease. Have to get the rubber good and tight before the old grease starts coming out of the nipple...but then it keeps coming for a a good bit.
When it comes time to change the lowers, I am going to roll with Proforged. Proforged same price as the 555 lowers, so I will give them a try.
Old 04-25-2019, 06:52 AM
ev13wt's Avatar
http://www.mittoyo.com/Store/index.p...oduct_id=35432
These ones?
Look pretty darn good "from here". Kinda like the oems. - good looking castle nut too.
arlindsay1992
05-25-2016 02:13 PM
Chooch
02-20-2013 05:20 PM
lunchbeast
10-05-2008 07:41 AM
coloradodragon
04-14-2007 04:59 AM
sigep4runner359
02-18-2004 07:21 PM
Quick Reply: best ball joint for 2nd gen 4runner
