Just did the starter relay mod -wow!
Old 04-16-2019, 03:30 PM
Melrose 4r's Avatar
Connected the starter relay to a dedicated 12V 30A fused line per RAD4runner’s instructions and all i can say is WOW!
I was skeptical(doubting Thomas) - i already had rebuilt the solenoid and my truck has a full GND cable to the engine block. But it would often, give me cause for concern sounding like it might not start, always at the worst possible moment.
The parts to do the mod cost about $15:
30 A fuse holder-walmart
Assorted pack of fuses- walmart
3ft length of 12 AWG copper stranded wire - Home Depot.
crimpable end rings - Home Depot
shrink tubing - already had some
My only concern was that my soldering iron might not be up to the task. But it worked. The whole mod only took about 15 minutes.
Even my son noticed the difference just hearing it start! Thanks, RAD4runner for driving this topic home.
The following 4 users liked this post by Melrose 4r:
ev13wt (04-17-2019), old87yota (04-16-2019), RAD4Runner (04-16-2019), SomedayJ (04-16-2019)
Old 04-16-2019, 03:48 PM
RAD4Runner's Avatar
Originally Posted by Melrose 4r
...doubting Thomas...
LOL! Glad you finally did it.
Link to Concise Description of Issue and Solution.
The following 2 users liked this post by RAD4Runner:
old87yota (04-16-2019), SomedayJ (04-16-2019)
Old 04-17-2019, 02:39 AM
wallytoo's Avatar
while you are at it, do the headlight relay installation, too. if you haven’t, it’s only a matter of when not if the hi-beams will stop shining.
SomedayJ (04-17-2019)
Old 04-17-2019, 03:24 AM
Melrose 4r's Avatar
thanks, i wasn’t yet aware of that problem.
Old 04-17-2019, 10:34 AM
wallytoo's Avatar
ray (rad4r) has several posts in his build thread on the installation, and the reason for doing it.
RAD4Runner (04-17-2019)
Old 04-17-2019, 02:01 PM
RAD4Runner's Avatar
I also added relay to my horn circuit so it doesn't sound like that little guy with big ears from Anaheim, CA with his balls caught in a trap - LOL!
No need to tear into steering column contact because not that contact carries low current.
HERE
Old 04-17-2019, 06:57 PM
Co_94_PU's Avatar
Cost cutting engineering at its finest.. Two dollar part removed from five hundred vehicles.. I just saved the company a million dollars, where is my bonus check?
I snapped the stalk way before the contacts wore out
Old 04-17-2019, 08:30 PM
RAD4Runner's Avatar
Originally Posted by Co_94_PU
Cost cutting engineering at its finest.. :
Our 1987 Honda Prelude had same issue after several years. I filled the pitted area with soldering lead but it eventually gave way, too. Replaced with OEM.
Always happy to give back to the community that helped me get started on right track with my truck that has since taken me to wild and pretty places.
Thanks to the parts list, Thomas!
AND Re: soldering iron, My
80-Watt Weller"><span style=80-Watt Weller" /> 80-Watt Weller">80-Watt Weller
has been so useful when doing thick wires away from plastics or electronics, AND welding cracks on kayaks. Home Depot has the $20 version.
Old 04-18-2019, 11:34 AM
coryc85's Avatar
Another vote for Ray's starter relay mod here. My truck had always done the click no start on those rare occasions, just enough to make it a pain but not really enough to root cause it. Fresh starter contacts didn't help, fresh battery didn't help. Then I did the starter relay mod and it never happened again. Been about 4 or 5 years. Good job Ray for figuring out the issue and informing people. Thanks for posting your results Thomas.
The following 2 users liked this post by coryc85:
RAD4Runner (04-18-2019), SomedayJ (04-19-2019)
Old 04-18-2019, 08:15 PM
Melrose 4r's Avatar
Thanks for the link to the 80w iron, Ray. I’ll have to get one of those. I don’t need more than 45 watts often, but when i do, i do!
Old 04-18-2019, 08:58 PM
RAD4Runner's Avatar
Most welcome, Thomas. Here's Home Depot's less expensive one... https://www.homedepot.com/p/Weller-8...0NUS/205542381
Melrose 4r (04-19-2019)
WMG092959
10-15-2019 01:15 PM
captainado
09-14-2017 07:04 AM
mojave3555
07-01-2017 01:56 AM
stanz
03-12-2014 07:38 PM
dutchboy
07-19-2008 04:25 PM
Quick Reply: Just did the starter relay mod -wow!
