Seeking Help with Temp Gauge Wiring
Alright so I am Tinkering around on my 87' Gen 4 pickup ,The Temp Gauge in the cluster is no longer working .I have located the Water temp Sender under the thermostat housing . The issue I am running into is the wire Running from the Sender to the gauge is no longer there ( previous owner cut it out ) So My question is , How do I go about restoring the gauge to working order ? Links , Website , Threads ? I have purchased a new Sender But am falling short on finding info about how its all connected . Any help is Appreciated
Nevertheless, temp GAGE sender is not under the thermostat.
It is hidden amidst and under the intake manifold.
Pls search within the forum using "google", search. Not "thread", Not "post". Latter two methods are LAME.
What engine is in your 1987 Truck? 22R? 22R-E? 22R-TE?
The sender for the gauge is in different places depending on your engine.
The sender on the 22R carbureted engine is under the thermostat between the thermostat housing and the mechanical fuel pump.
I have the 22R , I have located the Sender , What I'm lacking is the wire that connects the sender to the gauge , I havent been able to find a picture or diagram or info on the wiring .
looks like it should be a yellow and green wire.
It should be coming off your passenger side fender somewhere if I recall. I no longer have my 22r but a 3.4. When I first got my truck I just put a female compression disconnect onto it because the temperature sending unit had a male. I hope this helps.
EDIT:
YOTA TECH LINK WITH SIMILAR ISSUE
I did Ive read thru that whole post several times , It doesnt answer my question , I know where the sender is , Aside from that , The guy chopped out all the wires for it . I don't know how to read a wiring schematic very well . But Ive read the post from the Link It wasnt very useful to me
Luckily I’m at my Dad’s in Washington. I have my old truck up here with an engine swap but the wiring is the same and in the original locations. I’m at work right now but I’ll take a picture of it when I get home.
IRiot89 (05-18-2019)
IRiot89 (05-19-2019)
rfcruse
12-13-2011 11:30 PM
sethn
12-19-2010 07:54 AM
A_CavanaughWebb
11-29-2009 05:17 PM
frankentoyota
12-12-2008 05:21 AM
Tylerars24
08-10-2007 06:19 AM
