93 Toyota Pickup timing
Old 03-25-2019, 03:54 AM
Jooosshua's Avatar
I am looking to find out what the timing is supposed to be set at on these 22re motors. I have read where it should be at 5 degrees before tdc. And whoever set mine set it right at tdc.
Old 03-25-2019, 04:05 AM
ev13wt's Avatar
It's 5 degrees with the connector jumped.
- about 12 without the jumper.
https://www.yotatech.com/forums/f116...r-wire-212353/
Does your idle go down slightly when you set the jumper? If yes, set your timing to 5°.
If no, check TPS adjustment first: https://www.4crawler.com/4x4/CheapTr...PS/index.shtml
Old 03-25-2019, 04:08 AM
Jooosshua's Avatar
Yes my idle does go down with the jumper. Thanks for the help! I will fix it as soon as I get back to the house
Adrianchiino
05-16-2013 07:34 PM
4x4doog
11-04-2012 12:06 PM
lokirx7
01-29-2011 09:48 PM
4X4Yota4X4
All Other Toyota Swaps
01-23-2010 08:16 PM
WFR112373
07-08-2009 06:30 PM
Quick Reply: 93 Toyota Pickup timing
