Rear window switch???
Hello there I am trying to bypass the rear window switch that is located between the front seats, I have a 94 4runner parts vehicle that has no switch the window is up and I want to lower it. I was hoping there might be a way to put 12v directly to the motor from the switch connector?
Thanks!
Thanks!
thanks, I am just trying to jump the connector with a battery and put the window down so I can open the tailgate. It's a parts 4runner has a blown motor in it.
Not the ignition switch, the lock switch on the tailgate.
Do you have the battery connected?
Do you have power to the truck?
Can you turn on your ignition and see the dash board lights?
If the door open light is on you can't open the window, you need to play with the tailgate and try and get the door open light to go off.
Help this helps
Help this helps
as stated above, just insert your key into the lock cylinder on the tailgate and turn the key, one direction raises the window the other direction lowers it. the center console switch rarely goes bad. more likely the control box in the driver side panel behind the front seat.
Help this helps
Help this helps
also should mention that if the switch under the the hardtop bolt isnt depressed, the interlock prevents operation, and if the rear wiper isn't seated properly, it will trigger. AND if the window isn't up all the way and the wiper is also not seated at the same time, you've slipped into the twilight zone. try disconnecting the rear wiper motor, check the bolt switch (driver side near the rollbar I believe) and then try the key in the tailgate lock cylinder.
Disconnect existing connector from the motor.
OP worse case scenario but probably easiest is to pull the rear interior tailgate cover and jumper it from a car battery instead of chasing switches etc
[QUOTE=dropzone;52420862]most 2nd gens have the switch to raise/lower rear window from the center console
Humm,
Mine only has a lock/unlock switch, Am I missing a switch? There is an empty slot in the console and another wire harness laying there. My console has 3 slots, 1st is a coin slot, 2nd is the lock/unlock and 3rd is empty.
Humm,
