06 4Runner Fog Light Replacement - This Blows!
My 06 4Runner has two little OEM fog lights with H3 bulbs. I find them to be lacking. So I disconnected them and instead ran the wires to a couple 5" (maybe 6") PIAA lights that are mounted on the bull bar. I want to be able to use the OEM fog light switch. Everything went easy-peasy until I turned them on and immediately blew the 15A fuse. I'm certain my wiring job is solid. To troubleshoot I reconnected the OEM fog lights and the fuse doesn't blow. Reconnect the PIAA lights and the fuse immediately blows! I thought this would be an easy in-n-out operation.
I'm assuming my 15A fuse blows because the PIAA lights draw too much amperage. Is this right and what should I do to stop my fuses from blowing? I'm not known for my electrical acumen so please spell it out for me.
What lights, exactly, did you install? What are the specifications of these lights?
What are the specifications (wattage) of the H3 lights?
Do you have a link to the new lights you bought?
Either your new lights are drawing too much current or you have a short in your new wiring.
Does the fuse only blow when you turn on the new lights or when you plug them in?
Fuse only blows when I turn on the new lights.
Uhhhhhhhhh, dunno. I'll pull 'em apart and peek inside.
Just a little update for the sake of wrapping up this thread: The KC Pro6 lights are installed and work great. So obviously the problem with the other lights was they were drawing too much amperage and thus popping the 15 amp fuse. As a bonus, the new lights look great and provide much more lighting than the stock fog lamps. In fact, they provide so much more light that I gotta make sure they're legal. And I gotta make sure I have them aimed such that they don't blind oncoming automobiles. :-)
The ebay LED lights cast a pretty nice light these days and they are inexpensive. I just installed some yellow lights https://www.ebay.com/itm/2x-G4-9006-...72.m2749.l2648 for $25/pair. No modification needed.
1990Toy4x4
02-23-2014 02:10 PM
bill_collector
02-15-2012 06:39 PM
LilBeast
05-31-2011 06:03 AM
