Camshaft
Old 10-17-2018, 06:51 PM
Cumminsguy1's Avatar
Camshaft
Alright everyone I'm wrapping up my 22r build and picked up a cam that I got a killer deal on, it's a Crower 290/298. Lift . 433/417. Anyone running this cam? Did a search on it before I bought it and what few reviews I found looked pretty promising just wondering if any of you have tried it.
Old 10-18-2018, 03:56 PM
L5wolvesf's Avatar
Where are you racing and what does your have?
Old 10-18-2018, 06:41 PM
Not looking to have a race rig was just hoping for alittle more power here's a list of my build if that's what your asking?
-ARP Head Studs
-Dual Row Timing chain upgrade
-1mm over sized valves
-73lb valve springs
-stainless steel freeze plugs
-King engine bearing kit (.5mm)
-Piston and ring set (.5mm)
-valve spring retainers and MACHINED keepers
-Topline bear cylinder head
-New Harmonic balancer
-Ceramic high proformance clutch
-New radiator
-Crower Camshaft
-LCE Proformance oil pan pickup tube
-New oil pump
-New water pump
-OE Head gasket
-All new gaskets and seals
-Headers
Old 10-19-2018, 06:24 AM
L5wolvesf's Avatar
Yes, that is what I was asking about. What compression ratio are you going to be at and what induction system will you be using?
HurleyBoy
10-28-2003 10:07 AM
AllCammedUp
7
07-15-2003 05:52 AM
runningman
06-19-2003 08:02 AM
Skydigger
03-19-2003 09:21 PM
decepticon
09-27-2002 01:12 AM
Quick Reply: Camshaft
