Nerf bars install
If you're talking about some old Smittybuilt nerf bars (as opposed to modern rock sliders), the front mounts require unbolting the transmission crossmember and dropping it down just enough to get the nerf bar mount between the frame and crossmember. The rears do require drilling through the frame. Adding some sort of plate on the inside of the frame is highly recommended.
I know this because I just removed the ones that had been on my truck about a year ago.
See profile pic for what it looked like when they were on. (nevermind, guess they don't really show up, just the old Smitty front bumper)
At the very least you want thick wide "fender" washers between the lock washer and the frame.
This is essentially the anti crush tube I was speaking about, but more diy friendly as it doesn't require a welder to secure the tube.
Might have to wait for Bingle to post and see if he recalls how his were mounted.
Grab some measurements from the front mount's rear hole to the rear mounts front hole as well as how far the hoop sticks out from the frame/mounts. Someone with the frame section of a service manual can tell you for certain if these are regular or extra cab, or maybe something not.designed for the 83 Yoda.
Sorry, just saw this. Yeah, you likely have shortbox bars so you will have to do some custom work if you want them to go on your longbed. IIRC, mine lined up fine behind that mount. Between those cutouts in the frame maybe?
I would guess that vintage longbed Smitty's would be near unobtainable.
thank you.
L33T35T 4Runner
20
04-11-2003 03:05 AM
L33T35T 4Runner
13
03-23-2003 12:40 PM
AJatx
11-17-2002 09:16 PM
