Clutch hydraulic hose replacement
Old 09-19-2018, 02:12 PM
otravacaine's Avatar
I have a 1986 22rte 4x4 pickup. I have swelling in my clutch hydraulic hose, the rubber one or whatever. My question is, do I bleed the whole system dry to replace it and fill and re bleed, or do I just pop it out and bleed out the air. I can't find any info on this particular question. Thanks.
Old 09-19-2018, 06:39 PM
L5wolvesf's Avatar
I just did my slave and did the hose while I had things apart. Once I had the new slave and hose in I used a syringe to fill the hose and slave as much as possible. Then just keep doing the normal bleed procedure.
Old 09-20-2018, 01:15 AM
wyoming9's Avatar
Red face
Most times I do all 3 parts and just bleed normally .
I use a Vacuum Bleeder.
some people say gravity works well as long as you don`t run the master cylinder dry
Old 09-20-2018, 02:06 PM
One more question, for the rubber hose, do I disconnect the top or bottom first? The Slave cylinder was already replaced.
Old 09-20-2018, 03:36 PM
L5wolvesf's Avatar
Doesn't really matter which you disconnect first. But connect the new one bottom first, then fill with a syringe and connect the top.
supresmooth
04-10-2017 07:17 AM
habanero
11-10-2009 12:53 AM
HBoss
12-20-2004 08:45 AM
UKMyers
08-28-2002 06:11 PM
Quick Reply: Clutch hydraulic hose replacement
