Power steering problem
Hello guys i recently took my 1990 toyota pickup mudding and i had got stuck and turning trying to get out after i got home i relized im leaking power steering fluid from where the steering shaft meets the gear box is im guessing its a seal but is that an easy fix?
I'd start with the manual. http://web.archive.org/web/201209150...ng/13gearh.pdf The seal can be replaced, but the whole thing looks pretty daunting to me (lots of Special Service Tools; do you have a torque wrench that will read 4.3 inch-lbs?) With more information about your rig, the part numbers can be found here: https://parts.lakelandtoyota.com/sho...rimLevel=18381 The seal alone is not that expensive.
RockAuto has remanufactured units for around $200. I think that's the way I'd go.
lmddmc
10-09-2014 11:42 PM
rydholm11211
07-04-2013 04:45 PM
toyotatrdsr5
06-16-2011 12:15 PM
