94 3vz Timing is off?
So i bought a 3.Bl0w for $1,500 with blown head gasket. Ripped it apart not knowing as much as i should've and i messed up the timing. I set to TDC, checked and reset the cams and distributor, still no run.
Now I bought a new timing belt, see how it goes. Could I have messed something major up trying to start while timing is off??
Sure. But the 3VZE (I assume that's what you're talking about) is a non-interference engine, so cranking it with the valve timing off (alone) will not cause a valve-piston collision.
There are approximately 1,255 reasons why an engine won't run. Why do you think replacing the timing belt will help?
Welcome to YotaTech.
scope103,i don't know why i thought the timing belt would help, I guess i didn't know what else to do! (and i still don't). Crank, cams, and distributor all seem in alignment, I bought LCE headers with crossover delete which also deletes most EGR stuff. I capped off a few hoses but still not 100% i did it right. I dont think that the lack of EGR could keep it from running but idk. any help would be awesome!
#1 you have spark
#2 you have compression
#3 it is timed close enough to run
#4 you are not getting gas to the cylinders.
from there you will need to check the fuel pump, filter, EFI fuse, the injectors etc.
if it does not run you need to check #1,2, and 3
hgill
10-28-2008 05:57 AM
knaffie
05-23-2005 07:04 PM
