easiest way to remove cranshaft pulley
Old 07-24-2018, 12:30 PM
Republic77's Avatar
22 re out of truck, taking off pulley for installation on new motor.
tips, tricks?
No compressor right now, got hand tools and breaker bars.
Thanks in advance!
Edit: rope in cylinder, or make tool to lock flywheel?
Any others?
Old 07-24-2018, 12:53 PM
wyoming9's Avatar
Red face
With a Helper to put a bar through the drive shaft
I have used a pipe wrench on the drive shaft years ago
I cheat and spin it off with my impact
Old 07-24-2018, 01:32 PM
Republic77's Avatar
Thanks Wyoming,
I tried the rope trick and it worked, shoulda done a better search before I posted.
My trusty compressor took a dump on me, so I am doing things the old fashion way.
Old 07-26-2018, 08:37 AM
thefishguy77's Avatar
Another way I have done it out of the truck is with a short piece of angle iron and pull 2 of the small pulley bolts. Go get long enough grade 5 or better replacement bolts that allow you to connect the angle iron through properly aligned drilled holes. Then put a big breaker bar on the nut and break it loose. But when possible I use the starter method for breaking them loose.
Old 09-17-2018, 08:57 PM
Republic77's Avatar
Alright, now that my flywheel and crank pulley are off,the new parts are ready to go back on,
what is the easiest way?
Motor is out of truck, do I start with the flywheel, or crank pulley?
How do I fix the crank in place while I am doing the first end?
Also, I do not have a compressor so is it gonna be a very long bar to achieve proper torque?
Thanks in advance!
Old 09-18-2018, 06:18 AM
I think I torqued my crank pulley bolt last when I did my engine last time. Got it as tight as I could with a 1/4" impact then bolted the engine back to the trans in the rig. Stuck it in gear and blocked all 4 tires. Then put the torque wrench on it and hit the torque spec.
I had a piece of 1" angle iron I used for drilling hole and locking stuff up. Like I described in my post above. Pretty sure I may or may not have used that same technique with a fly wheel in the past as well.
Republic77 (09-19-2018)
Old 09-18-2018, 07:26 AM
gsp4life's Avatar
Crank pulley first. Last time I used a huge chain wrench which is what the fsm recommends (wrap the pulley to protect it), but isn't the best way. Better is to use a homemade tool to thread to the pulley like fishguy mentions. Torque it to spec.
Then you can put a breaker bar (with a cheater pipe unless you're a beast) on the crank bolt and tighten the flywheel bolts to 80 ft/lbs. It won't loosen the 116 ft/lb crank bolt or hurt the forged crank.
Old 09-18-2018, 06:46 PM
Republic77's Avatar
Thanks for the replies!
I am gonna make the tool that fishguy suggested and go from there.
Old 09-18-2018, 08:28 PM
Kolton5543's Avatar
I've used an old belt an c-clamp before. Wrap the belt around the pulley tight and pinch the belt together tightly with a small c-clamp. Loop the other end of the belt around a nearby bolt or pulley and torque as needed.
zlathim
61
12-18-2021 10:54 PM
everlastingz289
04-01-2018 12:41 PM
Nughuffer
04-11-2008 11:28 AM
VA_Yotaman
01-30-2006 10:51 PM
tomstin
26
10-14-2004 06:57 AM
Quick Reply: easiest way to remove cranshaft pulley
