dome light part
dome light part
I am looking for a replacement domelight for the 94 pickup. Did a few different searches on the forum and the only part numbers I found are for older models and then complaints of people who stated they bought a part that didn't fit.
For the 1994 Toyota pickup 4x4 what is the dome light led replacement ? A link to one would be great ...
81240-89103-S7 The last two characters are the trim color (S7 is light gray).
https://www.ebay.com/itm/8124089103S...-/182443542783
I gave up on factory dome lights and tweaked it
I am in the same boat, hard to believe it has been a year already. It sat in the driveway too long.
This little guy is my grandson. I was in the military when my kids were little. Missed a few birthdays and them learning to walk. The Lord sort of gave my a 2nd chance with the grandkid so figure I will make time.
From what I have read they give about 3" of lift. Not sure of the spring rate. 85toyman is running a similar set up I plan on running. His set up is clearing 35's with out issue. This thing will see the axles, front springs and tires from the Trekker
Old dome light switch gave up the ghost, tried soldering it but that lasted about a week. Dug into the parts stash and decided to make a small upgrade in brightNess
Attachment 112326
I may use the Duplicolor interior paint I have to make the housing color match but this will do for now.
Attachment 112326
Night shot of the new dome light
Attachment 112322
with the rear cargo lights and courtesy lights
Attachment 112323
Attachment 112322
Attachment 112323
Just the bulb??! It's a standard Festoon bulb, available at any auto parts store. (Measure it first; they come in different lengths.)
However, I recommend https://www.aliexpress.com/item/FEST...812695346.html The extended life shouldn't mean anything to you (I'll bet you're replacing the original bulb), but these are both brighter and whiter.
I got mine from https://www.superbrightleds.com/. More expensive but excellent customer service, although with such small-value items, OK to risk it with cheaper Chinese companies.
I still found the LED replacement anemic so I added manually-switched LED strip - option to use same as Dropzone's above- and my stock dome light is now used as my red nightlight.
This is the drop in led light from the website as suggested. Seems to be more than enough light for me. I took this in a dark garage. The ambient light is from a nearby stairway. Good buy ! Thanks for the suggestion
That’s the only one.
The seats in mine are pretty good. There is a coffee stain shown. I have the drivers side rip everyone does. Can’t find a seat with out it. Might just have them redone
gotcha, mine is a dlx single cab so it just had the single festoon bulb on the mirror, so I got the SR5 dual bulb one from the yard. One of the best upgrades I did holes are there you just have to slice a little bit of the headliner to mount it, but man I was excited!!!
weathernaut
05-08-2016 03:32 PM
CamTom12
04-20-2014 07:22 AM
fmg23
12-29-2005 04:54 PM
