xtra cab rear panel cargo nets
Old 05-16-2018, 09:00 PM
Toyota4Low's Avatar
Anybody know how to pop the cargo nets off the back of the cab? I want to replace the elastic band on top so I can use them again.
Old 05-17-2018, 03:11 PM
thefishguy77's Avatar
Hit the breaks real hard when you have something somewhat heavy on the shelf. At least that how my old picked one got removed.
Old 05-20-2018, 09:15 AM
slacker's Avatar
you need to remove the panel .
on the back side of the panel you see the posts and the metal retainer clips .
I used a small die grinder to cut the metal clips off , then the nets come off as an assembly . you can repair or replace them from there , and re install them . I found the replacement clips from a local car parts store .
Old 06-25-2018, 03:27 PM
Toyota4Low's Avatar
Awesome! Thanks! Looks like the previous owner had taken that off so it has the push pin things now. I will be rebuilding my carb tomorrow. May tackle that as well. Thank you!
jimbo74
10
11-02-2017 03:53 AM
mbomberz1
07-12-2014 08:00 PM
rdlsz24
05-26-2008 04:29 PM
NRM
7
04-26-2005 10:53 AM
Quick Reply: xtra cab rear panel cargo nets
