Block drain fitting
Old 04-21-2018, 08:19 PM
Oatmeal's Avatar
Block drain fitting
Okay,
I searched all over the internet and couldn't find the answer.
What is the size and pitch of the block coolant valve fitting? The actual valve that screws into the block on the driver's side. I want to install an aftermarket temperature gauge and want to put the sender there.....help!
BTW it's a 22RE
Hans
Old 04-22-2018, 09:15 AM
millball's Avatar
Technicly. it is a Japanese Industrial Standard thread (JIS), which can be hard to find:: but functionally identical to BSPT, (British standard pipe, tapered'); so..
The answer is::: 3/8" BSPT.
3/8 BSPT is 19 threads per inch, while ordinary American NPT is 18 threads per inch.
Old 04-22-2018, 07:03 PM
Oatmeal's Avatar
Thanks,
Upon further thought, I decided to go with a hose adapter at the upper radiator hose, I feel it will be at it's hottest before entering the radiator.
Factory gauge like most of them is giving me issues have several SR5 clusters and all read different!
Hans
tarra.dactyl
9
04-20-2017 10:21 AM
Kamo_82
04-22-2015 10:23 PM
vasinvictor
10-02-2013 05:01 AM
Zelephant
12-09-2009 07:23 PM
jjenks0
04-21-2006 07:24 PM
Quick Reply: Block drain fitting
