Plugs
Old 04-20-2018, 05:30 PM
rubronthroad's Avatar
Plugs
Wanting to change the plugs on a 91 toyota pickup, any recommendations? I recently replaced the plugs on our 2001 chevy prizm, with laser irridiums, was so happy with that thought, maybe I should use those on the truck.
Old 04-20-2018, 05:35 PM
old87yota's Avatar
Are you working on the 1991 with the 22R-E that is in your signature?
The 22R-E works best with the factory recommended plugs:
Denso: W16EXR-U
NGK: BPR5EY
Old 04-22-2018, 06:03 AM
thefishguy77's Avatar
Yep. Toyotas run great on stock plugs. Spend the money you save on shifter set bushings from Marlin or something that you will feel a big difference with.
Old 04-22-2018, 08:05 AM
az4x4runner's Avatar
I get the standard Denso copper plugs for my 3VZE, they are affordable and seem to work the best. Less than $2 each at rockauto.com.
Old 04-22-2018, 11:33 AM
Terrys87's Avatar
I get my plugs, rotor, and cap from the dealer ($43 dollars total from dealer). They are about the same price as the part store and much better quality. Stay factory on the plugs NGK or Denso. I get my plug wires ( Denso) from ebay.
Old 05-19-2018, 04:23 PM
Denso: W16EXR-U
NGK: BPR5EY
thanks olds, I used the ngk irridiums, very happy with them
Old 05-19-2018, 04:25 PM
​​​​​​​ngk are not stock?
Old 05-19-2018, 04:27 PM
[QUOTE=az4x4runner;52396669]I get the standard Denso copper plugs for my 3VZE, they are affordable and seem to work the best. Less than $2 each at rockauto.com.[/QUOTE
​​​​​​​the irridiums were bout 8$ each, everything is jacked here in hawaii, the improved results made it worth every penny
Old 05-19-2018, 04:31 PM
I just replaced the plugs and it was like night and day, so I did not bother replacing the rotor, cap and wires( wich I did buy, will put them on some day)
Old 05-19-2018, 04:32 PM
Thanks for all the replies, sorry it took so long for mine
edward watts
01-16-2018 01:41 PM
mkgarrison5
18
02-07-2007 08:35 AM
Ron(Fla)
14
10-19-2002 06:56 AM
Paul S
06-20-2002 05:07 PM
Quick Reply: Plugs
