ABS light comes on with bumps
Old 03-19-2018, 05:22 PM
temond's Avatar
We had new tires put on our 1999 Toyota 4 Runner and they had to replace a lug bolt. Now ABS light comes on when we're on a bumpy road. They had to remove the front left hub to replace the bolts, could this have caused the problem and what might the problem be?
Old 03-19-2018, 06:22 PM
RAD4Runner's Avatar
Mech could have messed up the sensor, its wiring or mounting.
Old 03-19-2018, 06:44 PM
temond's Avatar
thanks, that what I was thinking.
Old 03-20-2018, 06:16 AM
Malcolm99's Avatar
Debris on the sensor can cause issues you describe, it can pick up metal when being reinstalled.
I thought there was a slot to replace studs so removal wasn't necessary once the calliper was removed, maybe that was a corolla I'm thinking of, regardless this is why I torque them to spec 85-90ft/lb, I also never let any shop install my wheels and lugs, they always came back looking like a blind man put them on with an impact set at 130ft/lbs, I've also seen the coop students at the dealership standing on someones new rims to remove my gas tank for a TSB. Lesson learned, and I don't know why they put weights on the outside of a rim, I always ask they put them on the inside lip, rant off, sorry.
Rock Slide
37
04-03-2007 08:26 AM
JESSE_at_TLT
07-28-2006 11:40 AM
jakek
07-26-2006 08:40 PM
nm4runner
10-15-2004 08:33 PM
Quick Reply: ABS light comes on with bumps
