My 92 2WD when I remove the key the blower motor stays on
Its been doing this for some time, sometimes it's for half a second, some times several seconds. Today I had to disconnect the batter???
I wonder if your ignition switch is that worn.
The contacts are not opening like they should be.
Might be full of dirt that conducts electric
Any other switched power staying on like the radio , Wipers ??
Then with Toyota`s interesting working repairs turn up all to often
Unfortunately, it looks like the Toyota part is no longer available. https://parts.lakelandtoyota.com/sho...modelYear=1992 But it's just a 12v SPDT relay (and I'm not sure the double throw part is absolutely necessary), so you can probably find a universal version to fit. (Though the pin orientation doesn't look like the standard ones.)
wafoogalla
04-29-2013 05:51 PM
ChildrenOfBodom
124
06-24-2012 01:17 PM
