Need help
Need help
Ok so yesterday I dove my 4runner to town and came back, it drove fine. This morning I got in and started it up. Put it in to gear pull out of the drive way. And It would not pull up the the hill. It takes all gears just fine bUT wI'll not pull up any hills. I've change the transmission filter and the fuild. It will pull up hI'll in reverse only
When I was uder I did see my the my Pinon was wobbly.
There was no noise . I changed the trans fuild a month ago with a new fitter. The fuild was brown but did not smell brunt. I keep checking the fuild on a daily basis. This has happened befor but last time the transmission was low on the fuild. Thought that was the problem this time but it not. It will take reverse. It like it in high gear when trying to go up hillI did a video of how it is acking. I have jack up the rear end and went thew the gear from low to drive work fine. I don't know why it want pull on the road
Ok so today we got s ow down in ga . And these people don't know how to drive. Had a car drive off in the ditch. They had kids in the car. So I try to used the 4runner. I figure out that it will take 4 wl.but not 4wh.
I'm going to try to run the codes again tomorrow. What do yall think it could be
Just so you know, sometimes the fastest way to determine if you need a transmission rebuild is to put new clean slick fluid in it. The old gritty fluid is sometimes the only thing keeping it from slipping, and if it is already slipping.... I think you get the picture!
