'87 4Runner SR5 22RET WTB Fuel Sending Unit?
Should be picking up a new-to-me '87 SR5 22RET on Friday in Central FL. It seems that all of my '87 Turbo 4Runners have bad fuel sender units - the fuel gauge doesn't work. I plan to drop the tank and see if I can fix it - hopefully a stuck lever and not a bad wire. If it is shot, anyone know where to find a used/new one I could sub in?
Old Toyota OEM Part Number: 83320-39735
I've checked all the usual sources and this is the only one I've found a looks a little sketchy:
http://www.megazip.net/zapchasti-dly...61/pr-12369164
Thanks in advance for any leads.
Good luck if you can get that one go for it.
Last new one I bought was @ $120.00 and that might have been 10 years ago.
I have seen that some after market ones were around just how well they fit and work who knows .
If I ever need to replace a sending unit I think a New gauge and sending unit is the way I would go.
Anybody know of any other options. Anyone know of any junk yards with Turbo 1st gens with fuel sending units?
Update: I picked up the truck a month or so ago and have been overhauling it. 99% of the restoration work is now done and this is one of my final projects. Remember that this is a SR5 Turbo Automatic with a digital dash.
As as it turns out, the fuel gauge actually does work. But it’s odd:
- Fuel gauge shows Full Bars on digital dash from 0-100+ miles
- After 100-150 or so it drops from Full Bars to Zero Bars (empty)
- From 150-250 or whenever it is actually empty, it shows Empty with the Fuel Light on
My theory is that the float on the fuel sender is getting stuck in the middle of its cycle (cannot rise all the way up or drop all the way down) due to age. My prior ‘87 Turbo didn’t work at all, so at least this one works in the middle range.
Should I pull the tank and check the float to test my theory? Or due to the way these were made, is my guess flawed and i’d just be wasting my time?
I haven't looked at FSM about testing the gauge, but I think the float/sender simply presents a certain electrical resistance to the gauge circuit. Resistance varies with how far up or down the float is. You might be able to test the sender by measuring resistance when you know tank is near empty and when full. Compare with what FSM tells you.
To make it simple the float rides along a copper wound part different years had different resistance so mixing and matching might not always work .
the resistance changes as the level changes sometimes deposits build not allowing a complete circuit
Not sure if the RTE had a different sending unit .
I never cared for the digital dash replaced with the analog ones
Charles4x4, Checked if you can do same as this?^^^ No need to drop tank. I think dropping tank is only necessary on the pickup.
Per my reading, you’re exactly right. The float is most likely dirty at top and bottom and resistance isn’t reading correctly. See post from Maco35 here if you want to learn more:
https://www.yotatech.com/forums/f114...repair-252091/
Update: here is the proper sequence to get to the fuel sending unit on an ‘87:
1) Disconnect negative terminal on battery
2) Lift access hatch under rear passenger seat
3) Disconnext fuel filler and breather hoses and plug them with rags
4) Remove fuel tank skid plate (6 12mm bolts)
5) Drain fuel from tank
6) Remove 6 12mm bolts holding fuel tank up
7) Use floor jack to keep front of tank higher than rear so you can access fuel sender from rear
Pics below
Pics below
More pics. This is the sender you’re trying to get to - it’s back a little ways behind the fuel pump you can easily access through the hatch. It’s much smaller than I was thinking.
Now here is my problem. From studying the sender, it looks like the internal wiring in the middle is broken and the exterior housing is rusted. While it somewhat works, it’s probabky close to the end of its life.
Since this is a discontinued part, I was trying to fix it but I don’t think it is repairable. I’m not even sure I can open it up without destroying it - seems to be riveted together. Agree?
if not, where can I buy a new one for a Turbo that works with the digital dash?
Looks like I can take it apart per this post:
But his internal wiring wasn't broken like mine. Guess I'll pull it apart tonight and see where it goes.
This is the best I could do. After cleaning the lower half really good (getting the Black gunk off so the wires become shiny again), I got resistance up and down although it jumped around some due to the broken wires. It’s reinstalled so we’ll see how well it works.
Update: I haven’t used a full tank yet, so not a full report. But the sender seems to struggle at the top of its range (half to full) but i’m Hopeful the bottom half (which is what really matters) will prove functional.
