Diesel Swaps Diesel engines
22r bellhousing dimensions?
Old 09-21-2017, 05:00 AM
chrisw21_2000's Avatar
Ive searched high and low for the dimensions on the bell housing pattern for a 22r engine to make an adapter for someone. Can anyone help me?
Old 09-21-2017, 06:56 AM
millball's Avatar
Seems like the easiest thing would be to lay hands on one. They are common as dirt.
Old 09-21-2017, 08:41 AM
Im looking for a blueprint to draw it up for a cnc.
Old 09-21-2017, 09:04 AM
irab88's Avatar
http://r.ebay.com/tFRqG0
$25 shipped, and you can get the measurements as close as you want. No one here has blueprints; we all just bolt things together until it fits
Old 09-21-2017, 11:20 AM
Fossilized
dropzone's Avatar
this
seems like you would still want a bell housing so you know it would fit after your machine an adapter. No point in making something to sell or use if it is fubar because you were off, waste of machine time, effort and material
Old 09-21-2017, 12:52 PM
Yes... I have a bellhousing. But I need dimensions off crank centerline. These often can be found. This is the first time I've had trouble finding the information for an adapter plate. I just figured someone would have the dimensions without having to reverse engineer it.
Old 09-21-2017, 05:57 PM
irab88's Avatar
AH! A specific request! That helps US help YOU!
If you get a backing plate, the circle hole in the middle is centered on the crank centerline.
A quick goog-search revealed these:
http://www.mgexp.com/phorum/read.php?40,1372818
https://www.yotatech.com/forums/f162...s-such-279125/
Old 09-22-2017, 08:27 AM
Thanks, that was what I was looking for.
Old 09-22-2017, 08:29 AM
irab88's Avatar
I should start charging for my web-search services, haha!
Old 09-22-2017, 02:09 PM
Fossilized
dropzone's Avatar
yes, you are a master of the art of
