Standby Freezes Laptop...
Whenever I shut the lid to my laptop, it turns off the LCD immediately and goes into standby after 5 mins. That's normal for most laptops. However, when I open the lid back up, it's EXTREMELY EXTREMELY slow to get going again. It never actually DOES get going, because I lose patience in it and pull the plug and reboot.
What can I do to fix this? I notice it started doing it after the last time I reformatted and re-installed XP Pro. |
Also, I should note that I did the install with my slipstreamed copy of XP Pro with SP2 bundled into it. I wonder if that has anything to do with it...
Oh yeah... save your piracy comments. I copied my own disk for my own use. |
Do not have the answer for you, but if you do not want to do a slip stream in the future, you can DL SP2 from Microsoft's site as a file to burn to CD, and not as an install from the Update site.
The URL is in this months CPU magazine. I think I would rather install it that way instead of the slip stream method. |
Well, I changed the settings from standby to hibernate for when I close the lid. Seems to have solved the problem. Starts back up from hibernate lightning quick.
I did some more searching on the topic, and found that quite a few people thing it's linked to SP2's security center and their anti-virus programs. Didn't find a fix for it though, as turning off the security center does nothing to fix it, as does changing antivirus programs. |
Hibernate is working great... except for when I want to undock the laptop, because I use a docking station for when I'm at home. When I click "undock", it automatically goes to standby, and freezes when I open the lid. Any way around this?
Originally Posted by jruz
I don't think there is a way around that...other than shutting down. :(
You will probably have to work with your manufacturer and get the Standby problem fixed then... :devil: Jim So from now on, I'll probably just Hibernate to undock... :cry: :bang: :bang: |
