YotaTech Forums
-   Computer Talk (https://www.yotatech.com/forums/f98/)
-   -   Setting up HTTP on a server (https://www.yotatech.com/forums/f98/setting-up-http-server-66201/)
Corey Aug 27, 2005 02:03 PM
My friend Andy who runs the gaming server we have Counter Strike Source and UT 2004 on needs some help.
Here is his site:
http://www.allprogamer.com/
It is not done yet, and it will include a forum later.
What he wants to do is let members type in www.allprogamer.com/data to access that folder so they can download custom map packs and sounds from him instead of searching on the 'Net elsewhere for them.
Right now the only way folk's can do this is via FTP:
ftp://allprogamer.com
If you try http or www, no workie :(
http://www.allprogamer.com/data/
He can config Counter Strike in game to include "live" URLs to click on, but only html ones, and not ftp ones.
The server is running XP on it.
What does he need to do to turn this feature on?
Or is it even possible?
Here at YotaTech we can type in an URL for a folder and access files from it, and this is what he wants to achieve.
Thanks,
4RUNR Aug 27, 2005 03:44 PM
All you need to do is add a few lines into the Apache config file. Go to the section which explains aliases, there's a good description how to use it right in the file, and just add a /data/ alias which points to the same place on the hard drive where the FTP is looking.
Corey Aug 27, 2005 05:13 PM
Thanks, I will see if he can figure that out or not.
Churnd Aug 27, 2005 07:21 PM
Google .htaccess
You can configure a certain "folder" or web page to where only certain people with the right user names and passwords can get in.
Corey Aug 28, 2005 01:08 AM
Oh yeah, I use that on my own website so I can view any of my files in a folder as long as there is no index file in there.
He does not seem to have it set up yet with the Apache lines.
WT Aug 28, 2005 04:00 PM
Here something to check out if he is running XP pro its free and I did the same and built a quick web server with hotlinks to some files on a older laptop to serv up some videos.
http://www.webwizguide.com/asp/tutor..._winXP_pro.asp
