Mini ITX build
Going to build a computer, I haven't done this in decades..
Parts list so far. Mini-ITX board D945GCLF2 got Sata cable today.. 500 gb SATA laptop harddrive Tiny little power supply, need to get pics.. Going to make a wooden enclosure from the left over walnut from the crib 1 gb Ram, not sure came with the board Intel N270 dual core Processor 1.6 GHz 533 MHz FSB 512k Cache I might try to add a CD/DVD drive, but not sure yet.. |
why not max the possible RAM out to 2GB?
Cause the ram was FREE!
I got a copy of Win7 32bit for it too! |
oh...
well, free is nice I guess, lol |
i might get a new stick of ram its only about $30
System is up and running... now I need to build a case I was actually amazed that I could just plug in everything and it all worked, its been decades since I build a comp from scratch |
it's a lot easier than people make it out to be :great: assuming you have parts that are compatible with each other of coarse :roll:
What's the system gonna be used for?
I vote for another gig of ram too. |
Mostly built to be used with a DIY CNC machine or 3d printer...
secondary I'll probably use it to watch netflix movies and stuff in the bedroom |
Cool. You're totally gonna have to post the build for the CNC Machine or 3D printer when you make it, whichever you go with.
I suggest that you build a Mendel 3D printer, that way you can print out the parts and sell them to me for cheap. ;) |
Will do still deciding which to do... they both seem like a ton of fun..
Do you think you'll SAS it?:wrench:
Cool! If you can work on a truck you can build a PC :)
What are you going to use it for? SInce you have win 7, you can use DDR 3 RAM, and use MORE of it...and DDR 3 is cheaper than DDR 2. ZOTAC makes some great smaller motherboards, and some even have discreet graphics on them - check them out and good luck! |
Originally Posted by Outsane
(Post 51659901)
secondary I'll probably use it to watch netflix movies and stuff in the bedroom Intel says I can run these kinds of ram System Memory Features The Intel® Desktop Board D945GCLF2 has one 240-pin Double Data Rate 2 (DDR2) SDRAM Dual Inline Memory Module (DIMM) connector with gold-plated contacts. It supports: * 667/533 MHz unbuffered, non-registered DDR2 DIMMs * Serial Presence Detect (SPD) memory only * Non-ECC memory * Up to 2 GB of memory source http://www.intel.com/support/motherb.../CS-029532.htm |
Sorry, Outsane, totally missed that part :)
If you get the bug to build more, something to think about (DDR3 and ZOTAC) ;) I know you got most of this stuff free, so it's hard to disagree with you! |
If I get handed more free computers... I might...
I think making a DIY CNC or 3d printer will keep me busy for awhile |
| All times are GMT -8. The time now is 01:09 AM. |
