MessageApp
whenever i shut down my Inspiron 8200 with XP i get a prompt. it says the following program isnt responding and it asks if i would like to wait or end the task.
the program is MessageApp |
You have to find out what program is doing it. Do an MSCONFIG to see what happens at start up and do a CTRL-DEL to see the processes that are running before you shut down. Make two lists. Compare. See if you can figure out which program is not responding.
start -> run -> msconfig.exe ...find it under startup and uncheck it. You can probably uncheck a bunch of the other crap too |
check that link above, its got the answers. |
Originally Posted by data
Google rocks :bowdown:
| All times are GMT -8. The time now is 10:32 PM. |
