YotaTech Forums
-   Computer Talk (https://www.yotatech.com/forums/f98/)
-   -   different destop photo, dual monitors (https://www.yotatech.com/forums/f98/different-destop-photo-dual-monitors-135931/)
Hayes Jan 27, 2008 11:24 AM
I have tried searching google and haven't found instructions that have worked. I found one that made an internet addy permanent on my desktop but it only stayed for 3 minutes and then reverted back to the normal picture. I'd like to have my truck on one screen (or my favorite truck of the moment) and then some of my pictures on the other. I have one 17'' monitor and one 22'' monitor.
any help is greatly appreciated.
-Brandon
Tofer Jan 27, 2008 11:37 AM
i also would like to know :)
rdang Jan 27, 2008 11:58 AM
Try this, I tried typing in an explaination but even I got confused...
http://www.rocketrunner.com/images/monitor_desktop.jpg
Hayes Jan 27, 2008 12:18 PM
Right now I am getting the same picture on both monitors, I want two completely different pictures. What it sounds like you are saying would make it so that both monitors act like on with picture.
rdang Jan 27, 2008 03:54 PM
Can you tell me what your monitor resolution is on the 22 and 17? And let me know which one you have on the right, and which one you have on the left.
reggie 00 Jan 27, 2008 03:56 PM
It has been a long time since i figured this out.
Right click on the desktop
Select Properties
Select Desktop
Select Customize Desktop at the bottom
Click on Web
select new and browse to your "pic"
Make sure lock desktop items IS NOT checked
click ok
Click apply
At the top of the page it should have the all know minimize, maximize.
click on the maximize
should fill the screen
right click
arrange icons by
select lock web items on desk top
Hayes Jan 27, 2008 04:06 PM
1152 x 864 and 1680 x 1050
Select Properties
Select Desktop
Click on Web
click ok
Click apply
right click
arrange icons by
I will try this again, that is the one that wouldn't work before.
Hayes Jan 27, 2008 04:07 PM
17 on the left 19 on the right
Hayes Jan 27, 2008 04:15 PM
it works for all of 3 minutes and then goes back to a small version on the primary monitor...
DIHOWARD Jan 27, 2008 04:25 PM
You Can Have 6 Different Monitors, Yet You Still Only Have 1 Desktop! The Only Thing That You Can To Is Extend The Desktop To The Other Monitors.
Hayes Jan 27, 2008 04:30 PM
I've seen it done before. The way that has been described above seems to work for everyone but me.:(
I know it can be done...help.
rdang Jan 27, 2008 06:24 PM
You will have to adjust the positioning of the blue image on the left up or down depending on how you have your monitor positioned. You will also need to make sure that you have "extend my desktop onto this monitor" checked as well. When selecting your background image to use, make sure it is set to "tile".
Your desktop background image should be ONE image.
http://www.rocketrunner.com/images/monitor_desktop2.jpg
download full image here
reggie 00 Jan 27, 2008 07:18 PM
I'm not sure whats going on.
I do have the secondary image on the primary monitor.
i googled the how to many, many months ago. I have had multiple monitors up and running for a quite a while and i have since day one had two different pics up.
I changed my pic to double check and it works fine, The only thing i can think of is i have multimonitor task bar 2.1 running. but i think i put that in to get my orientation right. and to keep the programs running on monitor 2 over on monitor 2.
is everyone having problems with the way i wrote it up?
reggie 00 Jan 27, 2008 07:20 PM
http://www.howtogeek.com/howto/windo...-each-desktop/
looks like i might have missed one little step but this is basically what i do.
Hayes Jan 27, 2008 07:31 PM
I will try your way on my primary monitor and see if that works. Maybe it just won't work on the second monitor.
Hayes Jan 27, 2008 07:32 PM
that's the website I found weeks ago to try...same thing has been happening.
rdang Jan 27, 2008 08:02 PM
Did you try that image I uploaded Hayes? Just download the file size to your desktop and then right click on your desktop, properties tab, find the image, and then make sure it's tiled. Then go to settings and make sure your second monitor (19) has "extend my desktop... blah blah blah" checked.
This is assuming that your 17" monitor is your primary... your 17" should show blue, and your 19" should show grey.
Hayes Jan 27, 2008 08:33 PM
Is this supposed to help me set up different pictures or the dual monitors. I have the duals working, and have for several months. I may just be blinded by idiotitis (get it idiot - itis:hillbill: ) but I don't understand how this is supposed to help me.
Tofer Jan 27, 2008 08:47 PM
http://www.howtogeek.com/howto/windo...n-vista-or-xp/
that looks like the solution.. i'll wait till i;m at work with duals, then i'll try it
grayguy Jan 27, 2008 09:10 PM
ultramon. Download it, and make your life really easy.
