93 Toyota pickup 2wd (22re)
So I've been having an issue with my 22re; its misfiring/skipping while driving down the freeway and is holding the throttle steady at a certain rpm. The old motor had the same issue and was knocking so I replaced the motor with the rebuilt and I'm still having the same issue.
Fuel pump/filter was replaced. Spark plug wires, cap and rotor was reused. I checked for ground connection and it was good. All the injectors are ticking when I use a stethoscope to listen to the injectors.
Anyone ever had a misfire/skip issue let me know.
stanz
15
01-17-2017 12:01 AM
