88Toyota pickup ECU, to 94 ECU. Help!
I have an 88 pickup with a 22re from a 94. I would like to put a 94 ECU in it since the 88 ECU burnt up and now I don't have injector pulse. I have a 94 ECU and can get the pigtail for it. But my current pigtail is the 3 connector and the 94 is a 2pigtail connector. I'm trying to figure out how to wire it in right at the ECU. Both trucks are manual tranny. The 88 is a 4wd but the indicator light is the only thing I believe I'll be missing and it doesn't work anyway.
Thanks in advance |
Will any ECU from a truck prepared with an 22RE work if you want a new one?
192.168.100.1 192.168.1.1 |
| All times are GMT -8. The time now is 08:17 AM. |
