YotaTech Forums
-   GPS & Communication (https://www.yotatech.com/forums/f97/)
-   -   Scanner Install (https://www.yotatech.com/forums/f97/scanner-install-75287/)
Tim-in-TX Jan 2, 2006 10:55 AM
Scanner Install
Put it in last weekend. I knew there was a better use for the that space below the radio!
http://img425.imageshack.us/img425/9936/img00102ce.jpg
http://img425.imageshack.us/img425/6981/img00155jw.jpg
Rivalred Jan 2, 2006 11:03 AM
Very clean install... Looks nice.
midiwall Jan 2, 2006 11:37 AM
Did you do anything to mute the tunes audio when the squelch opens on the scanner?
What model is that? (edit: n/m, found it. Nice rig!)
Have you heard about the rebanding of the 800mhz freqs?
https://www.yotatech.com/forums/f5/radio-police-scanners-72542/
Compass Creek Jan 2, 2006 11:48 AM
Does that little pocket under the radio just pop out? I just bought a Cobra classic 29 and want to have it installed like your scanner. Looks ver y clean...and utilizes that space better too lol!
Dennis
Tim-in-TX Jan 2, 2006 04:16 PM
I don't listen to the radio very loud. It is more just background noise most of the time.
https://www.yotatech.com/forums/showthread.php?t=72542
I have been trying to keep up with it. I'm a member there also. It looks like I am relatively safe with the Pro96 & Pro2096. I will probably just need a firmware upgrade...but all that appears to be a year or so away. By that time, I will probably upgrade to a newer, better scanner! :bigok:
Tim-in-TX Jan 2, 2006 04:18 PM
Dennis
Well, the pocket came with the after market radio, and it just unscrewed from the radio bracket...reeeeeal easy!
