YotaTech Forums
-   GPS & Communication (https://www.yotatech.com/forums/f97/)
-   -   Handheld CBs? (https://www.yotatech.com/forums/f97/handheld-cbs-35078/)
Krash Jun 20, 2004 10:41 AM
Handheld CBs?
I've recently looked into getting a cb. While looking I've come across handheld cb radios. I got to thinking this would be good for me and my friends since they wouldn't install a permanent cb but think it would be a good idea that we all have them while on road trips or other outings.
Anyway, what are the general range on these things? Especially with no external antenna on the vehicle just the one on the handheld unit.
ldivinag Jun 21, 2004 06:47 PM
i have an old midland 805. sucky performance withi the rubber ducky antenna.
i tweaked an external mag mounted and i was amazed afterwards...
nice since i can spot people while i'm outside and they are inside the vehicle. this is before FRS.
E1 Jul 31, 2004 07:37 PM
You'd probably be better off with a frs radio. They will have a better range than the handheld CB, but if it is line of site offroad or highway either will do.
mt_goat Aug 15, 2004 06:13 AM
If you get an adapter to hook it up to a real antenna it should work ok. I hooked my handheld up to this K40 antenna once to test it out and it was ok. Lots of static but good range. http://community.webshots.com/photo/...69462139PtKSFk
The problem with the small radios is they don't have the good noise filters and full functions like the bigger ones.
