deserttoy84 |
02-07-2007 10:56 PM |
engine noise in cb... really wierd
Ok... I hooked up my cb radio. I got power from my amp because it runs directly to the battery. Then i installed a noise filter between that and the cb with an extra fuse on top of the one thats already in line on the cb wire harness. Im still getting noise when i drive. So how do i get rid of the noise thats is probably going through the antenna into my cb? THe wierd thing is that i can start my engine and rev it and it doesnt pick up. but when my truck is in motion it a fluttering sound to the enigne speed. So will an antenna filter work for my problem? Where do i get one? Also my antenna is a perm mount to the bedright behind the left side of the cab. are filters pretty common to use or am i doing something really wrong with my wiring? my ground is the floor of my cab. I have searched and people talked about the antenna noise test which is how i firgured it out. nobody really answered any of the old threads on how to fix the antenna problem so i figured ide ask since im sure somebody has been through my problem. thanks!!
