YotaTech Forums
-   GPS & Communication (https://www.yotatech.com/forums/f97/)
-   -   CB problem....help please.. (https://www.yotatech.com/forums/f97/cb-problem-help-please-78645/)
6lug Feb 12, 2006 04:52 PM
I dont know why, but my CB will not stop jumping to channel 9....every time i turn it back the the used channel, it jumps back to 9. Any reason for this?
Tofer Feb 12, 2006 04:57 PM
what type of CB is it? does it have power all the time or only when the trucks on? mine will auto jump to 9 when it loses power.
6lug Feb 12, 2006 05:00 PM
it has power only when the truck is on...its wired into one of the fuses. its a cobra from walmart...I forget which model...
Right now it doesnt have an antenna on it, but my wheelin buddies were close enough that I would pick up....do you think that it might be losing there signal and then jumping or no...
Bob_98SR5 Feb 12, 2006 05:07 PM
channel 9 is the universal emergency channel. i betcha you have something set where it defaults to ch 9.
read your manual :D
bob
Tofer Feb 12, 2006 05:09 PM
dont broadcast with no antenna on it.. it will burn out the crystal i've been told..
Ric Feb 12, 2006 05:56 PM
if you have 2 hot wires, one is red, one is orange.. one is for a constent hot, the other is for memory..
dont quote me on this part. the ORANGE is constent hot (for the memory), the RED is the power, to turn off with the key.
hope this helps.
6lug Feb 12, 2006 07:06 PM
Bob, thats what I was thinking, but I didnt know for sure if there was a default...you are right, I just need to read the manual...
Chris, I didnt know that...thanks.
Ric...I believe your right...thats how mine is set up...it turns on when the car is on ONLY.
Thanks guys,
Alex
Bob_98SR5 Feb 12, 2006 07:12 PM
Thanks guys,
Alex
now is this a cb you just installed? Has it worked before w/o this same problem?
my cb has a channel lock. perhaps that is what's preventing you from using other channels
bob
6lug Feb 12, 2006 07:27 PM
no...Ive had it for a little while, and yes it has worked without this problem before. It will change channels, but only for 5-10 seconds, and I can talk on them, but when I let off the mic, it goes to 9. I know thats the emergency channel, but Im wondering if its, like you said, on some default mode or if its messed up....i dont have a clue why it would keep jumping like that.
Bob_98SR5 Feb 12, 2006 07:31 PM
yeah, it does sound like a program/setting issue.
6lug Feb 12, 2006 07:35 PM
Well, thanks for your help anyway man.
Alex
Jeffires Feb 12, 2006 07:41 PM
The wiring advice already posted is probably more of an issue, but I know some radios have a switch to go directly to Channel 9 for emergency. See if it has such a switch, I had a Cobra that had it. And as ToeferUOP said, definitely dont key up with no antenna. Good luck. And if you can't fix it, take it back to Wal Mart because they guarantee customer satisfaction.
geordie Feb 21, 2006 07:22 PM
Actually it unloads the transmit section and burns out the power transistor in the output stage, but modern hardware often has protection against this.
