CB only buzzes?
Cobra 25, 7' firestik, 18' coax with fire-ring. Mounted on the back of my 87 4runner. I got the radio second hand but all the other parts are brand new. I don't know if the radio is broken or if I missed something on the install. I assumed it was all hooked up but I can't get anything but a low buzz from the speaker..
try unhooking the antenna see if that helps ive got a swr meter if you haven't tuned the antenna yet
I just put it all together the other day. I read someplace that using a cb without the antenna can fry it. .
same goes for having a antenna out of tune
any luck ?
Can you turn the squelch up?
I work a lot so I haven't had a chance to mess with it again. Adjusting squelch doesn't do anything. I hope to play with it again tomorrow morning. I'll check my connections again for the 4th time. If I still can't get anything I'll try to find someone local with a working head unit that can help me test things.
i should be in albany 2morrow ill shot you a pm with my number
| All times are GMT -8. The time now is 06:40 AM. |
