YotaTech Forums
-   GPS & Communication (https://www.yotatech.com/forums/f97/)
-   -   CB Install Problem (https://www.yotatech.com/forums/f97/cb-install-problem-87174/)
Isaracing Jun 1, 2006 08:41 PM
CB Install Problem
Istalled an older CB. Install went smooth and was very easy. Turned it on and everything sounded fine. Transmitted and it was fine. Next time I turned it on, all channels were blank, and upon transmitting there was a great amount of noise. Almost a screeching. Checked both grounds and they were fine. Checked the power and signal and both looked okay. All butt connecters with no soldering. The only thing I can think of is that it was raining the second time and not the first time. Brand new coax. Any ideas? thank you :)
rocket Jun 4, 2006 12:56 AM
Wet butt connections?
fourwd1 Jun 12, 2006 02:01 PM
Did you check the antenna VSWR ?
