4Puter Project (Toyota 4Runner Carputer)
Hi all,
I'm copying the pics and some of the text of the full article I posted in the Spanish 4Runner forum. Specs: - VIA EPIA M10000 Mainboard - 512Mb DDR RAM - Morex mITX Case with 12V 60W power supply - Combo DVD/CD-RW Samsung Slim - 80Gb Fujistu Slim HD - Sirf III USB GPS - Lilliput In-dash 7'' VGA Monitor, TouchScreen, TV Tuner and 4x45W amp integrated. ---------- The Morex mITX case and theSound Blaster Live 24 Bits USB I'll put in the glove box. http://img227.echo.cx/img227/7806/dsc026680bf.jpg The trunk compartment carputer adapted. I know cuttings aren't fine but they aren't seen later hahaha https://img308.imageshack.us/img308/...sc026653nz.jpg I reused the stock tools strap http://img308.imageshack.us/img308/9531/dsc026663xi.jpg Reinforced with alu to prevent the plastic box to bend http://img308.imageshack.us/img308/7631/dsc026675cc.jpg Testing. SB don't goes here, it was a test. http://img214.imageshack.us/img214/4341/dsc026729ii.jpg Here goes the box: http://img214.imageshack.us/img214/5821/dsc026739gt.jpg |
How to integrate an USB 4m extension cable and power switch and LED cables in one cord at a time? I did it with network 8 wires cable, 4 for the USB, 2 for the switch and 2 for the LED. It works!
Do do easier putting and removing the carputer without having to connect or disconnect things inside the case I used a serial 9 pin connector to integrate the LED and the switch connectors. http://img330.echo.cx/img330/7114/dsc026754hi.jpg I used the additional serial space to put it and connected it internally to the mobo. http://img330.echo.cx/img330/3323/dsc026769gv.jpg http://img330.imageshack.us/img330/8256/dsc026778pz.jpg Testing hw it looks http://img330.imageshack.us/img330/4315/dsc026789hj.jpg Hole seems done at size http://img330.imageshack.us/img330/5313/dsc026792en.jpg Yeah! http://img227.echo.cx/img227/7462/dsc026802cc.jpg What do you say I have in the truck Mr. Agent? :P http://img227.echo.cx/img227/6417/dsc026828mf.jpg Only rests the screen and a fan in the lid |
More pics
Glove box removed to do the holes https://img284.imageshack.us/img284/...sc028369sq.jpg Hole in the glove box bottom to the USB connector to pass through, it will go to an USB 2.0 4 ports hub. https://img284.imageshack.us/img284/...sc028387bt.jpg https://img284.imageshack.us/img284/...sc028398tc.jpg Joining the custom USB/LED/Swith cord https://img113.imageshack.us/img113/747/dsc028407zt.jpg https://img218.imageshack.us/img218/...sc028417xt.jpg Switch and LED place https://img218.imageshack.us/img218/...sc028427lz.jpg The wire that comes from the swith/LED and the one that comes from the trunk ready to join https://img218.imageshack.us/img218/...sc028445kh.jpg LED/Swith cords united (I've respected the same colors MoBo connectors have). https://img218.imageshack.us/img218/...sc028457ky.jpg LED and switch https://img218.imageshack.us/img218/733/dsc028467wr.jpg |
This is finishing
I've received the screen and I've begin to play with it... http://img284.imageshack.us/img284/1734/dsc028513oa.jpg http://img148.imageshack.us/img148/1010/dsc028535qw.jpg Soldering ISO connectors to the screen http://img222.imageshack.us/img222/1605/dsc028557ci.jpg Putting the frame (Look how it's different in european 4Runners than yours) http://img222.imageshack.us/img222/591/dsc028568hc.jpg Testing... http://img222.imageshack.us/img222/7508/dsc028601dy.jpg The connector made contact with the bottom of the radio hole and I could not push the screen so I trimmed it with care http://img222.imageshack.us/img222/6268/dsc028587lp.jpg And the final result, hidden (Yeah, I needed to clean the interior... I've done today) http://img284.imageshack.us/img284/3765/dsc028591pl.jpg |
Last pics
http://img319.imageshack.us/img319/4615/dsc028610oj.jpg http://img148.imageshack.us/img148/1011/dsc028628wu.jpg http://img214.imageshack.us/img214/1285/dsc028631ik.jpg Tipical videoclip pic http://img98.imageshack.us/img98/8349/dsc028658px.jpg As I'm not good designin skins I've added the Yota logo to the defaul In Car Terminal (iCT) skin. http://img98.imageshack.us/img98/8360/dsc028660lq.jpg http://img98.imageshack.us/img98/8308/dsc028673mc.jpg http://img138.imageshack.us/img138/8620/dsc028698ji.jpg Hope you like it. David |
David,
GREAT job! been wanting to do this forever. Now I have a great reference. :bigok: Bob |
If you want to do this you can use a normal 7'' VGA TouchScreen, integrating it in the double DIN hole you have... I prefered because I've to move down the screen to access the heater controls, but this is not a problem at all.
David |
wow thats nice :)
that is so sweet. awesome job!
how does the computer get power, do you have a dc to ac converter or what? |
The power supply is a DC-DC, works with 12V.
I'll replace it with a M1-ATX when I return from holydays because the M1 survives the engine cranks. I've stock dual batteries but diesel starters demand a lot of current so it drops below 11V and restarts the carputer. David |
WOW - I am very impressed - that looks SICK!!!
WOW x 1,000,000! That looks like a lot of work ... with an awesome outcome! Looks like something my brother would want to do. :D
Hope you used a good laptop drive. Ive installed a couple of these into friends cars, and the standard hard drive just dont hold up.
What Power supply are you using ? Ive had best luck with the Opus units, (Pricey but they auto start and shut down and handle the crank loads very well) |
Yeah, the HD is a 2.5'' unit. I'm using the standard Morex power supply, but I'll be switching into a M1-ATX. It can be configured to autostart and stop and survives engine cranks.
It also has a remote output for those using amps. David |
Nice. What Frontend software have you used ?
I Like Froodo player, and Media Car. |
nice work man! a friend of mine recently did this in his A4, really cool stuff. my only complaint (from using his) was the accuracy of the touch screen. i wonder if a small wireless mouse with a flip out pad would work...
That is danged cool. What GPS software are you running on that system?
Michael, I use In Car Terminal, you can test the shareware version from www.cartft.com
It's a lot more stable than other frontends like Frodoplayer, MediaCar, RoadRunner... The navigation system I use is named MapMonkey, it is designed to work with touchscreen and it uses the Destinator 3 maps. The GPS receiver is a Sirf III chip based one, it has got up to 9 satellites inside of home! David |
Nice job, I still can't figure out why the european models have only space for a single din radio. You could probably swap in a North American dash piece with the metal bracket which goes in behind to hold the double din + an empty pocket to hold some cd etc.
Yeah, I was at the dealer looking at the parts file and we saw it was interchangeable.
But as long as I'm not using any CD or radio (CD=carputer and radio=screen) I could save on this hehe. David |
| All times are GMT -8. The time now is 02:07 PM. |
